Old 11-30-2014, 04:13 PM   #1
Residential Fridge
My fridge will not work via battery. Battery shows full charge. Green light for invertor is on. Fridge works fine on shore and generator power. Any thoughts?
2014 GT 378 XL
jeffv003 is offline   Reply With Quote
Old 11-30-2014, 04:59 PM   #2
Residential Fridge
I think I remember reading about a fuse in the inverter, that may be bad or the inverter itself.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 11-30-2014, 06:43 PM   #3
cjd10's Avatar
There is a resettable breaker on the front of the inverter. Had mine open a few times. The green light on the inside will be on but no power to the refridgerator
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 11-30-2014, 06:56 PM   #4
Where can I find the invertor? Thanks for the tips.
2014 GT 378 XL
Old 11-30-2014, 07:49 PM   #5
cjd10's Avatar
Not sure on a 378. Mine is in compartment just to the right of the water heater. Have to remove the round white cap to see in. You should see the 120 V outlet on the front of it.
Charleston SC
Old 11-30-2014, 08:02 PM   #6
cjd10's Avatar
This is what it looks like when you find it. The reset is in between the outlets
Charleston SC
Old 11-30-2014, 08:44 PM   #7
My 2013 378 XL is locate above the LP tank. Take off the black plastic panel.
2008 Honda CR-V
Old 12-01-2014, 11:15 AM   #8
alsimmon11's Avatar
Took my 2010 GT 378 out this weekend. Turned on the fridge using LP when I picked it up. Once at the park I switched over to shore power. Temp was on 60 for several hours. Next day no change in temp, freezer was on but still no fridge. Switched back to LP and after about 4-5 hours temp started to drop. During the end of a 4 day trip the temp got down to 34. Normally it would take about 6-8 hours and fridge and freezer would be fine. Outside temp in Ca was around 70 deg. Any suggestions.
alsimmon11 is offline   Reply With Quote
Old 12-01-2014, 03:44 PM   #9
I don't know much about LP/electric but what I would check is to see if the electric element is working properly. Might even be a breaker, fuse or temperature sensor.
That is if when it is on LP it works fine.
I will ask a friend that has your type of fridge and let you know what he suggests.
2008 Honda CR-V
Old 12-01-2014, 03:57 PM   #10
My friend said if it works on LP but not on electric then check for a tripped circuit breaker.
Check to make sure heating element is getting hot.
Low heat can give a fairly cool freezer part and not a cold refridge area.
It could even be the control module.
Hope you can find the problem without much expense or hassle.
2008 Honda CR-V
fridge
