Old 08-22-2014, 04:31 PM   #1
Residential Fridge Drip Pan
I recently had my fridge worked on due to a dealership not winterizing it. Now I have a part where no one can figure out where it goes!! Does anyone with a residential fridge know where this goes?? HELP!!! :-)
ID:	61203   Click image for larger version
Chris
Cumming, GA
2013 Georgetown 351DSF
http://curban.smugmug.com/Urban-Fami...rgetown-351DSF
ChrisMSNT is offline   Reply With Quote
Old 08-28-2014, 09:59 PM   #2
dan-nickie's Avatar
Look up your model number on a refrigerator parts website. They typically have blow up diagrams that show everything. Good luck
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-29-2014, 12:05 AM   #3
What was wrong with the fridge due to not winterizing it? And what needs to be done to winterize it? Thanks for sharing.....as I have one and only 3 more months before I have to start doing it to my residential fridge.
sithc is offline   Reply With Quote
Old 08-29-2014, 08:24 PM   #4
Im not sure about residential fridge in a coach... But if its really a residential fridge Im pretty sure it's a drip pan for when the freezer goes into defrost mode to clear coils.... Take a good look under fridge front kick panel.. You should see slots where it would slide in...I'd get it back in there ... The defrost cycle doesn't cause puddles but will drip a bit...
Hope this helps....good luck
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 08-29-2014, 08:38 PM   #5
They didn't make pink ice cubes.... thus, it blew out the fridge water filter, ice maker, ice maker line, and main water valve. All in all, $800 worth of damage. I charged it back to the place that "winterized" it.
Chris
Cumming, GA
fridge
