Old 03-21-2016, 10:09 PM   #1
SimoRandy's Avatar
Send a message via AIM to SimoRandy
Residential fridge water stopped flowing.
I have a new GT 369 and the water flow stopped in the middle of my road trip. Any suggestions on where and what to look for? Tried a couple of local service centers that were useless. First they won't do warranty work if I didn't buy there and second, said it takes weeks to get warranty approval on fridges!
Randy S.
2016 Georgetown XL 369 & 2013 Jeep Wrangler
SimoRandy is offline   Reply With Quote
Old 03-23-2016, 01:26 AM   #2
ramair's Avatar
There is another thread that appears to be on the same issue someone else started check there posts, if its the same issue.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-24-2016, 06:15 PM   #3
I Break Everything
mikel68's Avatar
If it's a Frigidaire, you MUST call them. Our ice maker went out almost immediately. Didn't take long for them to come to us. Repairman brought a pump too. He said they go out as well. The pump is behind the fridge...yep, it has to be pulled if it's the residential fridge.
The guy that worked on ours gave me the new pump, and said here, this is for when it goes out. However it's still working. It takes a little bit to go through, have all your model and serial numbers ready when you call as well as purchase date. They found a repairman for us based on where our rv was parked.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 04-07-2016, 12:20 PM   #4
SimoRandy's Avatar
After talking with the always helpful Bryan at FR I was able to fix my water issue. There is a reset valve that leads to the fridge that for whatever reason popped on me. Once I reset it, all was flowing again!
Bryan gave me a few places to look and I found mine (GT XL 369) in the cabinet on the floor between the sink and stove. See picture. I'm also including his replay and photos in case anyone else runs into this easily fixed problem.
"It could be in a couple different places. I would check under the sink first since itís on the same side as the fridge. Itís just a white push button valve. It could also be in the convenience center outside or outer compartment near the fridge. I have attached a couple pictures showing what it looks like and where you may find it. I hope this helps!"
Name:	ImageUploadedByForest River Forums1460049269.492771.jpg
ID:	104175Click image for larger version
Name:	ImageUploadedByForest River Forums1460049284.557181.jpg
ID:	104176Click image for larger version
Name:	ImageUploadedByForest River Forums1460049298.716208.jpg
ID:	104177Click image for larger version
Name:	ImageUploadedByForest River Forums1460049315.961436.jpg
ID:	104178Click image for larger version
Name:	ImageUploadedByForest River Forums1460049326.934327.jpg
ID:	104179Click image for larger version
Name:	ImageUploadedByForest River Forums1460049338.399167.jpg
Randy & Sharon
RV'rs as of 2015
G-town XL 369 w/ wrangler hanging on the back!
Randy S.
fridge, water
