Old 01-12-2016, 06:51 PM   #1
Casper
williamsgw's Avatar
Residential Frig Winterization
Any idea on how to find water valve on frig. and to winterize the frig.
Instructions sent by Forest River doesn't look like my valve can be accessed. This coach is a 2015 328 TS.
williamsgw is offline   Reply With Quote
Old 01-12-2016, 07:11 PM   #2
AquaMan's Avatar
Look in a cabinet under the sink or near the fridge. It may be (most likely) a push/ pull type of valve with a 1/4" line coming out of it
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-12-2016, 07:53 PM   #3
in my 2014 328TS you remove the bottom drawer from the pantry to the right of the refrigerator. There is a round white access cover you unscrew to get to the valve. i had to lay on the floor to see the valve and reach it. it is a push/pull valve.
2014 Georgetown 328TS
2013 Chevy Sonic Hatchback
Houston, Texas
WayneT is offline   Reply With Quote
Old 01-12-2016, 07:58 PM   #4
Also, if the instructions Forest river sent to you are like the ones they sent to me, it would be almost impossible to hook up a blow out line at the valve as they describe. I blew out the lines from the city water connection and there seemed to be plenty of pressure to blow out the water dispenser on the refrigerator.
Houston, Texas
Old 01-16-2016, 12:55 PM   #5
My 2016 Georgetown 329DS has rollout pantry shelves to the right of fridge and the bedroom wall to the right of it. How do I access the fridge water line?
GHrv is offline   Reply With Quote
Old 01-22-2016, 12:46 PM   #6
Water line to fridge
Thanks! I found the shut off valve behind the rollout pantry to the right of the fridge!
Old 01-22-2016, 07:13 PM   #7
Jmsx2's Avatar
X2.
We have a 2014 328TS. Remove the white cap and push the valve up and it turns off the water supply to the fridge.
I went as far as disconnecting the feed line so in the spring when I flush the lines I don't get any pink in the fridge.
Very simple.
John & Janine
Pazzo the Maltese
2014 Georgetown 328 TSF
2013 Jeep Wrangler Rubicon (Toad)
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
winter
