Old 05-05-2015, 10:01 AM   #1
Johnnya's Avatar
Retractable stairs
Is there a way to disable temporary the retractable stairs when you open the door? I've parked my rv on the side of the road the other day and the stairs hit the curbside. I am trying to avoid that in the future not to damage the stairs.
2015 Georgetown XL 350TS FireMist | Firestone Ride Rite 4 corners air bags | Koniís FSD Shocks | Safe T Plus | BlueOx Rear Track| 5 Star Tuned | Centramatic's Wheel Balancers | Best handling Georgetown XL Bare None !!!
Johnnya is offline   Reply With Quote
Old 05-05-2015, 10:16 AM   #2
Iggy's Avatar
Many use a magnet that is placed near the door contact and that will keep the steps from going out. I use this when parking along a curb so the steps don't go out. I usually jump in and out that way.
If you are handy and hand an old microwave that is trash you can remove a very powerful flat circle magnet that is mounted around the magnetron tube. That is what I use. They are about 2-3" in diameter.
Here is what they look like. This is two stacked together.
2012 Georgetown XL - 378TS 63K + miles
Old 05-05-2015, 10:20 AM   #3
Johnnya's Avatar
Hmmm. I have to find this magnet. Thanks for the hint
Old 05-05-2015, 10:48 AM   #4
Iggy's Avatar
Check Craigslist as many people give old microwaves away working or not in the FREE area. If you find one for free close to you it is worth the time to take it apart for the magnets.
Also you can pick a small cheap one from a Harbor Freight store.
Old 05-05-2015, 06:22 PM   #5
bubbles's Avatar
One other point. The steps stop coming in and going out due to current rising when they reach their extreme positions and therefore it will not damage the steps if they hit a curb or some other obstacle when deploying. That is the way they are designed. However; IGGY is correct with one solution if you want to keep them from going out when you open the door.
Old 05-05-2015, 06:29 PM   #6
Johnnya's Avatar
Good to know, thanks
Old 05-06-2015, 09:52 AM   #7
You can buy bar magnets at any Lowes or HD. Cheap and easy to find and I've been using them for years.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-06-2015, 09:54 AM   #8
Johnnya's Avatar
Where do you locate the magnet ?
Old 05-06-2015, 10:17 AM   #9
On the door frame you will find a sensor with a corresponding sensor on the screen door. These sensors are usually white in color and maybe and inch long or so. Place the magnet on the sensor located on the door frame and the step system will think that the door is closed all the time and the steps will not deploy.
Lostdog
