Old 12-14-2015, 01:17 AM   #1
ramair's Avatar
Reworking the Inside Appearance
Well been thinking of applying high gloss clear (varnish) to all the wood inside of our 2012 378XL. I think that this would add a very nice updated look to the wood and make it appear more high end. Gonna be some work but I believe the end result could be worth it. Can anyone think of a downside to a project like this.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 12-14-2015, 04:54 AM   #2
To each their own. For me the high gloss looks like cheap plastic. I prefer the rich wood look. It's your motorhome though and you should do what you like. Good luck with your project.
georgew48 is offline   Reply With Quote
Old 12-14-2015, 07:39 AM   #3
I would do it the way you want. It's like watching the home improvement shows on tv. They are alway stressing what is good for resale value. We have always remodeled with out likes instead of what someone else might like.
Filthy Beast is offline   Reply With Quote
Old 12-14-2015, 08:00 AM   #4
Is the wood trim and cabinet faces in a Georgetown "real" wood? I assume the cabinet doors are but isn't the other stuff the standard RV run of the mill fine vinyl veneer? If that's the case its not going to take varnish or poly too well. You might end up with a hell of a mess.
Mr Havercamp is offline   Reply With Quote
Old 12-14-2015, 08:11 AM   #5
Canadian Contingent
Dogpatch's Avatar
I agree! Try an area not as noticeable before you carry on doing the rest.
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 12-14-2015, 08:27 AM   #6
My thoughts exactly. Much of the wood trim is not really wood at all and I wouldn't recommend that "light sand" process that most varnish will require for adhesion.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 12-14-2015, 09:05 PM   #7
Steelhorzz
Steelhorzz's Avatar
Beware..... Most of the "wood" on the inside of your coach, (at least ours), is just a vinyl appliqué. I know as we have some scratches in our RV, (Georgetown 360), and it's just pressed wood underneath.
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
Steelhorzz is offline   Reply With Quote
Old 12-14-2015, 09:43 PM   #8
Iwannacamp's Avatar
Water based poly may not be an issue. You can buy deglossers for prep...just make sure it is compatible. A simple cleaning may be enough.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 12-15-2015, 06:51 AM   #9
Wolverine 1945's Avatar
I am not sure what condition you real wood is in,,,
But I would do the same as I do with every pic of wood in our home,,,
At least once a year I oil all wood with Lemon oil !!!
Makes our over 20 year old cabinets,,, look like new !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-15-2015, 06:56 AM   #10
Even water based poly is not going to bond to the fine Corinthian vinyl veneer. It will eventually start peeling.
