Old 04-08-2016, 03:53 PM   #1
Happily Retired Member
Ride vs tire pressure
The past couple of years we went to Florida and I-65 in both the Montgomery and Birmingham, Al areas were like driving on a washboard. It just beats you to death and almost rattles your teeth. I usually have tire pressure at 90 PSI cold, front and rear. My tires are 255/80R/22.5 and my 378 is on a 24,000 lb chassis. Tow dolly tongue weight almost nil. Based on numerous FROG forum input, my front axle will be real close to 7700 LBS and about 15200 on the rear, ready to roll. I have been thinking of lowering the pressure per the Michelin Tire specs to 75 or 80 on the front and 80 on the rear. I know that lower tire pressure causes faster wear to some degree, but don't know the effect if I am with in the tire specs. Wondering if this may help the harsh, beat you to death ride on rough roads. Does anyone have any input as to ride vs pressure vs wear? Thanks.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 04-08-2016, 04:01 PM   #2
Commercial Member
You have no idea what your actual loads are on your tires unless you get on a scale. Corner weights are what you really need to know but lacking that you should assume a 55/45 side to side split in load for each axle. Using the load/inflation tables you then can learn the MINIMUM inflation needed. You should then add 10% margin so you don't drop below the minimum inflation needed when temperature drop or the tires loose air through normal air permeation.
Also if you are going to cut it close you need to have your air pressure gauge checked against a know accurate gauge. Running a TPMS is also very good insurance and can easily pay for itself with the first low pressure warning.
However I doubt you will feel much improvement in ride by lowering pressure 5 or 10 psi.
Tire durability (life) is also reduced when you run lower pressure not just tread wear.
Note the above inflation pressure info applies to motorized RVs not to trailers.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 04-08-2016, 09:55 PM   #3
jergeod's Avatar
That five or ten pounds will make a big difference. I figured mine the same way as you were trying to do and it worked out perfect I'm running a 22000 pound chassis and I run 80 pounds front and rear. Made a big difference in handling and ride but it still wasn't good so I added some sumos to the unit and that is what made the big difference and now it rides great.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 04-08-2016, 10:07 PM   #4
Tireman9, in a previous post a 378 loaded ready to go was 7716 lbs front axle and 15200 lbs rear axle, and my 378 would be extremely close to the same weight. Although I usually do not run with much water. I am comfortable using that weight. I do have A TPMS system and my tire pressure gauge is within 2psi. I don't have corner weights, but even if I did you can not run different pressures on the same axle. You have to go with the higher of the two. I was simply looking for information as to trying to help with the harsh, bone rattling highways, but do not want to run a low pressure and cause premature tire wear.
Jergeod thanks for the info. I may drop the pressures and give it a try.
2013 GT XL 378TS
Fire Mist
Old 04-08-2016, 11:57 PM   #5
SKnight's Avatar
It will help. How much is debatable and only you can be the judge.
If you want to find exactly what tire pressure each axle likes, you need a tire crayon available at any parts store, a flat parking lot, and an afternoon.
Fill your tires to their max pressure as indicated on the sidewall. Don't worry about recommendations for now and no disaster will befall you.
Go to your flat parking lot, then use the crayon to draw a three inch wide stripe all the way side to side across the tread block. Do this on all the tires. Then hop in, and drive forward about 20 feet. You want the tires to turn at least twice. Try to watch the valve stem and stop with it at the same place you started so you can see your marks.
Then look at your crayon marks. Chances are the center will be gone, but not the sides. The high pressure causes the center to bulge slightly. Drop the pressure five psi, fill in where the crayon was rubbed off, and drive forward again. Check, color the block back in, and repeat dropping the pressure each time. As you get close you can drop less pressure at a time.
Once the crayon block is evenly rubbed off, that is your pressure the tire likes under that load. Don't drop below minimum recommended pressure.
What this does is establish even pressure across the tread block, which is what the inflation charts do if you know your actual weights.
The next morning when the tires are cold check the pressures, but it shouldn't vary much since odds are they won't be too hot driving to then playing in a parking lot. Reset the pressure to your new number established in the parking lot, and give it a try.
Old 04-09-2016, 08:14 AM   #6
jergeod's Avatar
Mickeystamper, just be sure you are using the pressures recommended by the tires you have and their chart.
George & Jerri
06 GT 340 TSSE
USMC
Old 04-09-2016, 08:57 AM   #7
Jergeod
I do have specs page, thanks
2013 GT XL 378TS
Fire Mist
Old 04-09-2016, 12:17 PM   #8
Steelhorzz
Steelhorzz's Avatar
I've driven on and off road all my life. Motorcycles, 4WD, passenger cars, RVs. I've always run the recommended air pressure in all my tires. Not only will you get better tire wear, but you have improved handling and control while cornering and braking. Plus lower inflation pressure too much can cause the tire to spin on the rim or come off during a hard corner. (Not that I think dropping from 90 to 80 lbs would cause this).
But as far as improving handling I have ALWAYS had my best results with suspension "mods" and upgrades. (Shocks, Steering Stabilizers, Springs). On my 360, I've added Sumo Springs, and a Steering Stabilizer. The difference in handling is "Night and Day"!!
And of course I drive per road conditions. If I need to slow a bit, I do! Nothing is that critical that I have to be there at a particular time. I can always call ahead and update the folks at our next stop.
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
Steelhorzz is offline   Reply With Quote
Old 04-09-2016, 12:44 PM   #9
Georgetown 280
What are sumo's? We are looking at making our ride more comfortable, but have been quoted over $2k for a stablizer kit. Any other suggestions would be welcome.
Mike and Cheri Ferguson (and Laci)
2013 Georgetown 280
Penn Valley, CA
MikeFerg is offline   Reply With Quote
Old 04-09-2016, 01:30 PM   #10
Danesville's Avatar
If you search the internet you will find Sumo, they mount between your frame and leaf spring for better ride and sway control. I have been thinking about getting them as all I have read and heard are good things.
Danesville is offline   Reply With Quote
Old 04-09-2016, 02:13 PM   #11
Commercial Member
255/80R22.5 at 80 psi is rated for maximum load of 4300 single and 3860 dual. Sure hope you have confirmed no sire is in overload at any time.
Old 04-09-2016, 05:41 PM   #12
jergeod's Avatar
Sumo springs will cost about $600 front and $600 rear, not cheap by any means but they do work. Look on Etrailer.com for the best price. You need to order by your chassis and year.
George & Jerri
06 GT 340 TSSE
USMC
Old 04-09-2016, 06:54 PM   #13
Steelhorzz
Steelhorzz's Avatar
You can find Sumo Springs at a lot of different sites, even Amazon. They are springs encapsulated in a high density polyurethane material, and mounted between the axles and the frame. They control the movement of the body during cornering and especially winds!! I put them on my 2012 360 after my second trip! What a difference in handling!!
To put it bluntly, after installation I can drive down the road with a strong crosswind with only one hand on the wheel and a cup of coffee in the other! Before, I drove white knuckled, both hands on the wheel. Worth every penny !!! Questions?? ��
Old 04-10-2016, 01:34 PM   #14
Tireman9, you are right. If I drop to 80 PSI, I have cut my safety factor too close. Overall with the enhancements I have add, the 378 drives and handles well. So with that said, I am at 90 PSI. Thanks forum for all the discussion and inputs.
2013 GT XL 378TS
Fire Mist
Old 04-10-2016, 08:29 PM   #15
Vince and Charlette's Avatar
On my 2015 GT 364, I've spent $3,200 on heavy duty Roadmaster front and rear anti-sway bars, steering stabilizer and rear Tracbar. All of this combined netted a moderate improvement. I'm going for he Sumos next since I've heard some good things about them. But then, every type/brand of modification has its staunch advocates. On each thing I've purchased, I was influenced by more than one person saying this is the one mods that does it all. So, be careful who you listen to. On the other hand, I have to admit that the more trips I take (14K in the last 12 months), the better I am at handling my GT. So, experience helps.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 04-11-2016, 07:05 AM   #16
This is something I have been wondering... Do you need the Sumos and the upgraded anti sway bars? I read that the Sumos are supposed to help with sway, but maybe that isn't their primary purpose. I would be disappointed to spend $3200 and only improve things moderately. Which set of upgrades is considered better or more important?
carmex is offline   Reply With Quote
Old 04-11-2016, 07:21 AM   #17
For me, the new front anti-sway bar seemed the most effective when compared to the other mods I did. I first tried the CHF, but it made the OEM sway bar hit the bottom of the frame in turns causing a loud clunk. So, alignment shop specialising in RVs undid the change noting they had undone the CHF on other GTs. It should be mentioned that I have 19.5" tires, but neither FR nor Ford are willing to say it makes a difference. We like our 364TS so much (3 teenagers) we have not tried to upgrade to a DP, as we once intended, since none have as good a floor plan for us.
2018 Berkshire 38A
Old 04-11-2016, 08:33 AM   #18
I don't have much wheel time yet since we've only had or GT 364 for a few weeks. We haven't gone on our maiden voyage yet, but I have taken it out on the road a few times to get a feeling for how it handles and how to properly navigate turns and corners. I added the roadmaster Steering stabilizer for safety reasons in case of a blowout but it has added a bit more stability with regard to keeping the wheel centered. The combination of the 6spd tranny and the steering stabilizer has made me wonder how I would ever justify another 150-200k for a DP. I'm not sure there is a better "bang for buck" out there for families traveling with kids on a few vacations per year than the 364TS. At least for those of us that are not full timers and on a budget (such as myself). In order to get all of the features offered on a 364 on a DP, I would bet it would be almost double the price......
Melvinson404 is offline   Reply With Quote
Old 04-11-2016, 08:48 AM   #19
Melvison404. Staying debt free is really the top reason we stayed away from the DP. However, there is little doubt that it's a better ride with more power, which is why they cost so much.
2018 Berkshire 38A
Old 04-11-2016, 09:44 AM   #20
We're hoping to get our order placed for a new 364TS today. Our plan is to start full-timing this fall for anywhere between 1 and 3 years. We are a small family (only 3 of us) and plan to do some modifications to turn the bunkhouse into an office for me to work. I'm curious why you feel the 364 might not be a good fit for full-timers. I too feel like it's one of the best bang for the buck out there and want to make sure I'm not missing anything that would be a problem using this thing full time.
Thanks!
pressure, tire
