Old 04-11-2013, 10:53 AM   #1
Pete
gartonhl's Avatar
RM1350 icemaker water inlet valve?
Happy winter camping to everyone! (ha!)
We're fulltimers. We were in Denver this past Tuesday when winter storm "Walda" passed through the area. Temp dropped to 7 degrees. Failed to disconnect the water supply line. The icemaker water inlet valve to icemaker froze in our 2010 378TS.
Lesson learned: Even when fulltiming, you still must protect your fridge components.
Has anyone with the Dometic RM 1350 fridge replaced their icemaker/water dispenser water inlet valve solenoid assembly? Where did you purchase the valve? I can't find it online......
Pictures attached. Any help is appreciated.
Thanks in advance,
Pete
ID:	27655   Click image for larger version
ID:	27656   Click image for larger version
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 04-11-2013, 08:49 PM   #2
Send a message via Skype™ to Falcon35
The same thing happened to me last spring.
I had a local Dometic service man check it out and he didn't know what to do.
The valve was under the arctic pack foil and we could not see the split on the valve.
So when I got to AZ in January I took it to Lazy Days RV and they ordered the valve from Dometic. We are now on our way back to Ontario and my hit some freezing temperatures so I have shut of the water techto the valve and taken the line of and drained it. When the teck put the valve on he didn't replace the foil or the wires for the arctic pack properly properly so I will have to check that out when the weather is better.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 04-15-2013, 09:47 PM   #3
VinceU's Avatar
Thanks in advance,
Pete
I've seen the valve listed as a complete assembly from Dometic on a 1350 parts list. When I downloaded it a year ago it was 95.00 plus change available from them. Not all parts are available for resale, but many are. Make sure you download for your model.
Old 04-16-2013, 08:43 PM   #4
The valve for mine was $126.41 at Lazy Days.
2008 Honda Fit
Protect-A-Tow
Old 04-17-2013, 10:19 AM   #5
VinceU's Avatar
Here's the list!
I attach the parts list the valve is piece #376 and lists for 99.44
Sorry the file won't upload. But heres Dometics part #:
385111 6024 is a 12/v/120v coils and valve manifold
3763851116024VALVE, WATER$99.44
Hope ya find it ok.
