Old 06-10-2016, 06:41 PM   #1
Bayouownbeer's Avatar
Rock guard
Is a rock guard necessary on the 364TS with the factory mudflaps?
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 06-10-2016, 09:44 PM   #2
Iggy's Avatar
It depends on if you value your toad.
A mud flap will stop rocks coming off the tires but if you hit a tire casing the Roadmaster Rock Guard will stop it from flying up and hitting the car.
I had this happen and the tire casing actually damaged the large Roadmaster rock guard side flap and cracked it at a high point which deflected the tire casing from hitting my car.
Now if you have an old clunker and don't care about it don't get one.
The yellow line shows where the tire casing hit and was deflected.
2012 Georgetown XL - 378TS
Old 07-21-2016, 11:03 PM   #3
The mud flaps in the fender wells do stop about 80% of the rocks, if they are wide enough (1" further out on the inside edge and outside edge) and low enough to the ground.(within 6")
The mud flap on the back, as long as it is at least 4" off the ground, will stop the rest, and it will be a great help when you have to drive over the alligator in the road.
NRose is offline   Reply With Quote
Old 07-22-2016, 10:58 AM   #4
Send a message via Skype™ to Falcon35
I use a Protect a tow.
Protect-a-Tow
My Tod is a Honda Fit so is very low and I find the Protect A Tow helps a great deal. It is also easy to hookup as I just rap it up over the tow bar when we unhook. When I hook up I just snap two clips on to the car.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
