Since there's no picture I cant tell you exactly, Most have little tabs if you look close enough. Just push tabs and pull. Have seen some you squeeze and pull. Some you move cover one way and pull up, if all else fails a pocket screw driver usually does the trick. It does not take a lot of pressure, so if your fighting it........stop
2015 274 RK LIMITED <'{{{{><
