Old 08-20-2015, 07:48 PM   #21
It sounds like the problem has to be documented as best as possible. I haven't sent my pictures into FR yet. I have been too busy. You can see what eyc said about his 2009 in an earlier post. I can't imagine what it would cost to replace the roof. When it's a warranty problem in the first year, it needs to be fixed or replaced.
Roger2650 is offline   Reply With Quote
Old 08-20-2015, 08:51 PM   #22
Document document...,I'm working with Travis at FR.
It's very concerning especially on a new MH. Mine is in the same location, just above the drivers side on the edge. It's where the roof has the brown paint. It's interesting how many of these are popping up. Curious.... When was your Georgetown built. Wondering if these with the roof ripples were produced around the same time..like a production issue etc...if I remember right the sticker next to the drivers side was Oct 2014...
I used a divot lap sealants on e flat areas that I thought needed touching up and on the side & ripple ares I used Profex RV clear. This is what the RV shop gave me and said to use.
So would this be covered under the one year warranty or is this considered structure?
Mr. G
MrGrmpy is offline   Reply With Quote
Old 08-20-2015, 09:39 PM   #23
tilap's Avatar
Mine says 5/14 as manufacturing date
tilap is offline   Reply With Quote
Old 08-20-2015, 10:12 PM   #24
Dijoeboss's Avatar
I think my 2013 XL has the same ripples, I will get up there and take some pics as well..... I never thought of it to be an issue, I thought it was normal for it to look like that.... Who knew?!!!
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 08-21-2015, 12:32 PM   #25
Mr G:
Mine was manufactured Oct. 2014. This defect should be covered under manufacturers defect. Which falls under the one year warranty. All the appliances are covered under their individual warranties. The chassis is covered under Ford Motor Co.
I am surprised that FR is giving others the story, that there isn't a problem. I'm staying on top of this problem. I'm not letting them get away with it.
Thanks for letting me know what your dealer recommended to seal the area, just in case this gets dragged out a bit. I will look into the Profex clear. I already have Dicor self leveling roof caulk.
Roger
Old 08-21-2015, 06:42 PM   #26
undr60's Avatar
Most warranties actually start on the "in service date" which is the date the first owner purchased the coach. The manufacturer date doesn't matter except to see if there was an issue with others put together during that time. I hope all of you are successful in getting FR to step up and do the right thing.
undr60 is offline   Reply With Quote
Old 08-21-2015, 07:25 PM   #27
Dijoeboss's Avatar
Name:	ImageUploadedByForest River Forums1440203116.135982.jpg
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 08-21-2015, 07:26 PM   #28
Dijoeboss's Avatar
Roof Warranty??
Name:	ImageUploadedByForest River Forums1440203195.527872.jpg
ID:	86487Click image for larger version
Name:	ImageUploadedByForest River Forums1440203209.395644.jpg
Not very pretty!!!
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 08-23-2015, 06:41 PM   #29
I have the same ripples on my 2014 351 - figured it was to help with water run off since it's the same on both sides and only on the front. 3 years left on my extended warranty so I'll keep an eye on it.
ttincali is offline   Reply With Quote
Old 08-23-2015, 07:37 PM   #30
xman123's Avatar
i also have the same thing ripples on my front i figured it was from flexing i also am keeping an eye on it
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
roo, roof, warranty
