Old 05-25-2011, 11:06 PM   #1
Canadian Georgetown 369XL
Schwing2008's Avatar
Round Ceiling Light
Has anyone had to change the bulb in one of the ceiling lights
If so, what is the trick
I have taken the whole fixture out of the ceiling with the springs, but struggling to get the bulb changed
Help?
Alberta Canada
Schwing2008 is offline   Reply With Quote
Old 05-26-2011, 01:04 PM   #2
Pete
gartonhl's Avatar
It wasn’t easy. I learned the hard way by dropping down the entire fixture; then learned how it was setup. See pics below.
The glass cover to the fixture, however, “CAN” be removed without dropping down the whole fixture. I learned to spray some WD-40 into the fixture and glass to make it a little easier.
I used some “non-skid” drawer lining to get a better grip. Use the palm of your hand (or thumb and forefinger) to turn “counterclockwise” as you’re looking up at the fixture. It’s “kinda tough” to get traction and get it going, but it does work. The glass is thick, so I don’t think the glass will break if you don’t exert heavy upward pressure; just firm pressure turning counterclockwise. Once the glass comes out, you can pull out and replace the spent bulb.
As shown in the pics, the glass cover has two opposing indentations that fit into the two neoprene clips in the fixture. Turn clockwise to re-attach. I put some white grease on the glass cover edge to assist when there is “a next time”.
If you do drop down the whole fixture, just take out the bulb holder attached to the white wire in the first picture below.
Hope this helps.
ID:	5988   Click image for larger version
ID:	5989   Click image for larger version
ID:	5990   Click image for larger version
[FONT="Comic Sans MS"][B]Pete and Patty
2019 Forester 3011DS; 2016 Jeep Grand Cherokee Overland
Lab/Catahoula/Greyhound rescue
gartonhl is offline   Reply With Quote
Old 05-26-2011, 07:27 PM   #3
Kanadian Kamper
kenandterry's Avatar
I recently had to replace the bulb in one of the lights over the kitchen counter........I think they're the same?????
Anyway.......turns out the actual bulb was not available in the automotive section where other 12V bulbs are found. I located them in the lighting section and supplies for residential bulbs for some of the more exotic lamps and lights. Although the bulk of the light fixtures here would be fed with 120VAC, there are models which step the electricity down to 12VDC for the actual lighting.
Ken and Terry
kenandterry is online now   Reply With Quote
Old 05-26-2011, 07:32 PM   #4
sherdep's Avatar
the other thing you could use is one of those rubber round jar opener as well to get a better grip if the drawer liner doesnt work
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
