Old 07-12-2011, 10:56 PM   #1
Round Louvered vents in ceiling
Camping mates, I have several round, white louvered vents in the ceiling of my 2005, Georgetown 375. I have almost nothing coming out of them when I have the A/C on, most if not all of the cold air is escaping from the vents on the A/C units themselves.
When I have the heat on, likewise there isn't anything coming out of the vents either. Since this past weekend was the first time I needed to use the A/C, I haven't had any exptectations of what would come from the vents. (and yes, I did open them!!!)
Thought you smart RVrs could help me out.
Ron
Rongrice is offline   Reply With Quote
Old 07-12-2011, 11:05 PM   #2
Herk7769's Avatar
Are the Air Handler "dumps" open? In most floor plans you have to choose between the "fast cool down" from the "dumps" or a more distributed air flow from the vents.
If your dumps are closed and you still have poor air flow, you will need to check the ducts for a blockage.
HAM CALLSIGN - KC3FFW
Old 07-12-2011, 11:11 PM   #3
Where would you find that option
Would this be inside the A/C unit itself? Not really sure I have ever dealt with this sore of thing before.
Thanks for your reply though
Ron
Old 07-12-2011, 11:17 PM   #4
Herk7769's Avatar
Not sure if I have a photo of the air handler with the cover ON!
But there are slide doors on the air handler (the place where the filter is located on the ceiling). Those doors are "dumps" for rapid cooling of the living area. They divert all air flow from the entire camper to the area directly below the air conditioner.
Old 07-12-2011, 11:35 PM   #5
jsutherl's Avatar
On my it's a set of louvers on the inside cover of the AC unit itself. Right next to the filter. There's a little slider. If you push the slider one way lots of air comes out right there. Push the slider the other way and it blocks the air dump. Forcing the air to go to the vents.
I only have one AC unit. When it's running and the air dump is closed you can tell air is coming out of the round vents but not a lot comes out. Still it cools things off pretty well.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 07-12-2011, 11:37 PM   #6
Thanks everyone
I will try this in the morning.
Ron
Old 07-13-2011, 12:49 AM   #7
ronhanson's Avatar
As stated, you have to have the vent on the ac unit itself closed to develop enough pressure to divert air down the vents in the ceiling. Its an alternate path for airflow that allows quick localized cooling. To really feel it out the ceiling vents you need both ACs going since the outlet surface area is so large and they are connected.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 07-13-2011, 01:10 AM   #8
Nigels's Avatar
"When I have the heat on, likewise there isn't anything coming out of the vents either."
I didn't think the airco acted as a heat pump, (like the ones we have at home), we use the furnace for heat or am I missing something?
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 07-13-2011, 01:14 AM   #9
onequicksportster's Avatar
I believe the heat just comes from your furnace throught your floor vents.
2015 F250 psd CC Sb 4x4
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
onequicksportster is offline   Reply With Quote
Old 07-13-2011, 07:55 AM   #10
I also have the ducted AC on our new 21SS. You simply close the 3 vents on the AC unit and the air gets directed out to the other vents. Works great and much quieter in that mode. You can also spin the smaller vents to direct the cold air where its needed more..
Hybrid21SS is offline   Reply With Quote
