Old 12-08-2013, 02:57 PM   #11
Iggy's Avatar
Originally Posted by 43D18 View Post
Well, rub it in, Iggy.
Not to hijack the thread, and you can msg if you prefer, but curious how you include the US states map in your sig line. Thx!
-Mike
Just select the map and select the states and make it.
Then copy to your computer and add it to your signature.
Visited States Map by epgSoft
Old 12-12-2013, 12:37 PM   #12
I like the idea of the blanket and light bulb with out the light being under the blanket, but hanging or some place safe in the engine compartment so the bulb doesn't melt a hose or start the blanket on fire.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 12-12-2013, 05:04 PM   #13
Send a message via Skype™ to Falcon35
I don't think the manufacturers suggest doing that.
We did do that kind of things years ago now they tell us not to idle an engine.
Start it and after a short time drive gently until it warms up then drive it long enough to bring it full temperature.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 12-12-2013, 05:51 PM   #14
Originally Posted by ramair View Post
we hit zero last night and I just start the engine and gen every month for approx. 30 just to keep everything working properly. Never heard of letting it run everyday. Individuals and car lots don't run vehicles everyday when its gets cold. Ask him his reasons. Would like to know. Running everyday won't hurt nothing..
X2, in Northern Massachusetts
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 12-12-2013, 08:11 PM   #15
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
sorry to laugh guys but here in NH it gets down to -35* in February. All we do is make sure we have a strong battery, nothing extra, no blankets, no light bulb, dont idle for extended periods. Just in the morning give it 10 minutes before hopping in on those hard seats. Southbound we are coming in 15 days.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 12-13-2013, 07:23 AM   #16
I'm guessing that theory is coming from having to deal with older cars. Nowadays, with modern technology (i.e. oils, fuel injection, etc.), there is no need start the engine every so often. All you have to do is make sure your fuel doesn't go stale and maintain the battery.
I restore old bikes here and there and I have a 78 Kawi that struggles to start in less than 60 degree weather. Anything above 75 and starts within two kicks. Oh, and the carbs are so tight that you really have to drain the bowls or a tiny amount of gasoline varnish will make it run bad.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 12-13-2013, 07:31 AM   #17
For the price we're paying for newer ones guess it must be newer tech. That makes them easier to start.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
Old 12-13-2013, 11:44 PM   #18
Rig info in signature
Originally Posted by Krazymace View Post
We hit -23 last night here in Central Oregon. Record cold. My wife's cousin, who is a mechanic, said I should run all my auto and motorhome engines for 30 minutes every day. Never heard of doing that, but guess it wouldn't hurt. Better idea is to take it south, which we intend to do next month.
Just a friendly bit of advice, it is helpful to provide accurate answers when you include the make and model of your rig in your signature block.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 12-14-2013, 08:57 AM   #19
Iggy's Avatar
This question has all types of answers so I might as well add mine.
At -23 degrees things do get hard.
I need to know what is the temperature mid day?
How long of a very cold spell does the weather forecaster predict?
My answer with the limited information.
If your MH cooling systems has proper antifreeze and this cold snap is only a few nights and day warms up to 10 degrees above zero or more, no problem.
If you were to leave your MH for a few weeks in sub zero temps and have weak batteries I can see a problem starting back up.
Oil and antifreeze will get thicker only in prolonged sub -zero weather.
For short term no problem.
But when you are ready to drive off you need to warm it up. I would insure you warm up the transmission by putting in neutral during warm-up. And move it thru the different positions before you drive off. This will insure ATF is warm and flowing well thru the valve body and torque convertor.
Everything should be warmed up within 10-15 minutes.
OK that is all I have to offer.
Old 12-14-2013, 12:52 PM   #20
dashonthedash's Avatar
In Colorado, it's illegal to leave a vehicle running unattended on public streets (called "puffing"), but it is OK to do it on private property (like your driveway). It's part of an attempt to discourage easy (opportunistic) car thefts, as thieves watch for running, unattended vehicles, and can find and drive it away in seconds. I start the motorhome occasionally during the winter, but to start it every day and leave it for half an hour, even in your own driveway, is tempting fate (and thieves) a bit too much.
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
