Old 06-20-2016, 06:43 PM   #11
Originally Posted by RSchleder View Post
The poster stated that their frig worked for 3 years on batteries! I think the first thing I'd do is pull the batteries, take them to a shop and have a load test performed. After 3 years, you could be reaching the end of the useful life of your RV's batteries.
X2. Sometimes a battery can be fully charges yet will not stand up to a load. 3 years is a good time to replace.
You might try running of the TV for little while, assuming that battery is good.
ornery is offline   Reply With Quote
Old 06-24-2016, 04:33 AM   #12
360true's Avatar
OK now it has happened to me. Residential fridge on my 378 runs on shore power, and on generator. Not on batteries. GFI on inverter will not reset (pushes in, but does not stay). Unit has not gotten wet. Circuit breaker inside is OK. GFI in bath is OK. Batteries are fully charged. Seems that power is reaching ProWatt 2000 inverter. Green light on. LED panel flashes 14.5 then 000.
What do I check next?
360true is offline   Reply With Quote
Old 06-24-2016, 06:59 AM   #13
360true's Avatar
Follow-up... I called tech support at Xantrex. They suggested I turn off ALL power to the coach including turn off the matter switch for an hour to let it reset. I did, no fix....
Old 06-24-2016, 07:28 AM   #14
Can you remove the load from the inverter then try to reset the GFI?
If you can then you know the issue is down the line.
if not then the inverter has an issue.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 06-24-2016, 07:32 AM   #15
clr
I would call Xantrex support back with this information and see what they now say. From your description of the error code and the GFCI not being able to be reset it sounds to me like the Xantrex unit itself may of gone bad. The 14.5 is the voltage to the unit but the 000 should be flashing a valid error code E00 - E10.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-24-2016, 09:30 AM   #16
That's just their way of delaying you until they get off work so it's someone else's problem
carmex is offline   Reply With Quote
Old 06-24-2016, 11:17 PM   #17
SS396CV's Avatar
360true, mine stopped working too. I tried to reset the GFI and it would trip again. Then I reset the GFI by forcing the reset button in for a number of seconds and then it held and worked the rest of the trip. We ill see tomorrow when we travel again.
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 06-25-2016, 07:23 PM   #18
360true's Avatar
Ss396cv.... wish mine was so easy.... also spoke with three dealers as I cut across Maine, New Hampshire and Vermont - they all said the same thing that now thru July 4 is their busiest time of the year.... call me mid July.....
Old 04-05-2017, 12:12 PM   #19
I know this is an old post, but did any of our members who posted here ever conclude what was the root cause? My 364TS is exhibiting the same behavior as described in the original post.
Maxwell32 is offline   Reply With Quote
Old 04-05-2017, 12:36 PM   #20
SS396CV's Avatar
Mine has been working correctly until yesterday. The GFI would continue to trip on the inverter. Not wanting to lose the food, I used the generator and ran it for half an hour. After shutting down the generator it worked again as it should. I will be checking the house battery connections, the first time it didn't work I noticed the battery connections were loose, tightening them up seemed to solve the problem, I will see if that is the problem. Other than that I have no clue what the problem is.
Has anyone else found a cure?
battery, fridge
