Old 06-19-2016, 07:04 AM   #1
swiseman's Avatar
Running Residence Fridge on Battery
I know I've read about a solution to this issue before, but I can't seem to find it...
My residential fridge works fine on shore power and with the generator, but when can't seem to get it working from the batteries/inverter. Is there some sort of reset or circuit breaker on the inverter I need to know about? I have 2014 328 TS, and the battery indicator says Batts fully charged. It worked fine on batteries/inverter for three years, now...
Thanks all!
Scott & Lauren
"On the edge of Normal"
2014 Georgetown 328TS
States Camped: Illinois, Wisconsin, Iowa, Nebraska, South Dakota, Minnesota, Michigan, Indiana, Ohio, Missouri, and Ontario CA.
swiseman is offline   Reply With Quote
Old 06-19-2016, 07:07 AM   #2
Ddubya's Avatar
Chances are that the frig draws to much current for the inverter
Ddubya is offline   Reply With Quote
Old 06-19-2016, 07:17 AM   #3
RSchleder's Avatar
The poster stated that their frig worked for 3 years on batteries! I think the first thing I'd do is pull the batteries, take them to a shop and have a load test performed. After 3 years, you could be reaching the end of the useful life of your RV's batteries.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 06-19-2016, 07:31 AM   #4
There is a GFI on the inverter itself, at least there is on mine, which is a Xantrex. Look on the back of the inverter. Does the inverter turn on? If there is, press the reset on the inverter GFI.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 06-19-2016, 12:05 PM   #5
Ddubya's Avatar
Guess I should read the entire post. Have you checked the voltage out of the inverter?
Check battery connections for corrosion.
Old 06-19-2016, 12:15 PM   #6
Before you start lugging batteries and going after corrosion and the like, make sure that the inverter is actually running at all. The fridge will load it down, but with no load it should still be putting out 120 VAC, and have some lights and displays that indicate that it is working.
2015 335DS
Old 06-19-2016, 01:06 PM   #7
Happily Retired Member
Thanks all!
My 378 has an inverter switch at the entrance steps near all the other interior lights, etc.. It is a black switch with a green light when on.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 06-19-2016, 01:09 PM   #8
First thing is to check to see if the green light on the ON/OFF inverter switch is lit. If so then check to see if the GFCI is tripped in the inverter itself. If that is okay then it could be the transfer switch next to the inverter. That transfer switch in a small 4" x 4" black box made by Xantrex, it switches power from the Xantrex inverter to shore/generator power.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-19-2016, 02:05 PM   #9
X2 - Also check to make sure the battery disconnect switch didn't get bumped to off. Guess why I mention it........grrr.
FroggyRon (Ron)
2014 Forest River Georgetown XL 377
2014 Jeep Cherokee Latitude 4X4 toad
FroggyRon is offline   Reply With Quote
Old 06-20-2016, 10:38 AM   #10
Be sure the icemaker is turned off when running the refer on batteries. Will keep the battery draw to a minimum.
kenkaiser is offline   Reply With Quote
battery, fridge
