Old 06-16-2009, 11:18 AM   #1
Running the Generator
Ok, I've done this before but just can't remember....I'm a liveaboard that is hooked up to shore power. I need to periodically run my generator. Do I need to disconnect from shore power when i do this or just stay connected to shower power. Do I need to shut off any circuit breakers?
The generator manual just says to shut off the AC or major appliances.
I think I've done this hooked up to shower power before but just not sure and want to make sure I don't hurt anything.
Please help. Thanks.
georgetown50 is offline   Reply With Quote
Old 06-16-2009, 02:42 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
You can stay plugged in. You're just exercising the generator. There will be no load on it since you're still plugged in. My invertor has a setting to exercise the generator automatically every 30 days or so and it runs for about 30 minutes. I'm plugged in the whole time but I don't have any major appliances running. It has no effect on the charger side of the invertor when it's running with shorepower.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-16-2009, 06:50 PM   #3
Head Rambler
In order to exercize a generator it really needs to have some load on it. if your inverter is as cfoistman's and has a generator exercize mode then unhooking from shore power shouldn't be required. I'm sure the inverter puts some load on it. If you have to do it manually I'd shut everything off and start the genny then run the A/C for a little while.
Gotta go campin!
Old 06-17-2009, 04:13 AM   #4
Ok, and you just need to run it for about 30 minutes?
Old 06-17-2009, 06:49 AM   #5
Head Rambler
Right, That's long enough to get the engine up to operating temp and drive off any moisture that's accumulated. It's also long enough to get the genny end up to temp too. Spreads the lube around and all kinds of good stuff.
Gotta go campin!
