Old 02-14-2016, 12:10 PM   #1
RV gps
Which one allows you to add propane to your profile
JerseyJerry is offline   Reply With Quote
Old 02-14-2016, 07:09 PM   #2
Iggy's Avatar
None
Old 02-15-2016, 08:02 AM   #3
5er_tom's Avatar
We RV more than 120 days each year. Only buy propane twice a year. Sure don't need a tracking device for that.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 02-15-2016, 08:23 AM   #4
I think the Rand McNally 7730 allows you to add "maintenance reminders" so you could figure how much propane you use and add a reminder when to fill up, or if you're asking about hazardous gas through certain tunnels I believe this does it too.
2016 Apex 300BHS
TV: 2005 Silverado Z71, 4x4 lowered and re-geared
ApexBunk is offline   Reply With Quote
Old 02-15-2016, 10:16 AM   #5
Jim34RL's Avatar
All of the Rand McNally GPS allow you to add propane and how many bottles you are carrying. This is under the RV Tools on the Home Screen. First you need to select preferences to pick either car/light truck or RV. When you pick the RV icon you than go back and you can select the RV tools and enter all of your parameters for the RV including the number of Propane bottles and size. This information is than used to route you accordingly when you are in the RV mode. Such as low under passes and tunnels that will not allow propane or exceed bridge weight limits. There are also Check, Maintenance, Trails and Fuel list on the GPS that can be used.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 02-22-2016, 08:47 PM   #6
No need to guess when you can easily add a remote propane sensor. I got the Tech Edge iSeries system and it includes a propane level sensor.
I haven't installed it yet but it looks like it will monitor EVERYTHING very accurately.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 02-27-2016, 11:04 AM   #7
Agreed on the Rand McNally RV GPS
Carmen is offline   Reply With Quote
Old 02-27-2016, 12:31 PM   #8
Oakman's Avatar
A heads-up about the Rand McNally GPS and I’d bet this probably applies to all brands of GPS. If you use the POI (point of interest) in your GPS to locate a campground, be sure to verify it has the correct location of the campground. With each upgrade Rand McNally has gotten better but it still has some campgrounds incorrectly located in the POI directory. I know you don't want to be driving in your RV on some small city street and have the GPS tell you, "you have reached your destination," and there isn't a campground to be seen.
I use the Good Sam campground directory since it has the GPS coordinates listed for RV parks and campgrounds so that’s what I program into the Rand McNally.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
