Old 11-26-2013, 05:01 PM   #1
Dijoeboss's Avatar
RV in storage, can i leave coach heat on?
I'm using my coach over the holiday, but it's bitterly cold here now and colder tonight. My unit is in storage and I want to leave the coach heater on, can I do this ?? It will be burning propane... Or is NOT an good idea??
Dijoeboss is offline   Reply With Quote
Old 11-26-2013, 05:03 PM   #2
iceblaze580's Avatar
You could do it but your furnace will draw your battery's down pretty quick
iceblaze580 is offline   Reply With Quote
Old 11-26-2013, 05:14 PM   #3
Dijoeboss's Avatar
Even if unit is plugged into. 110v? Or should I use the heat strips ?
Old 11-26-2013, 06:29 PM   #4
The heater on propane is a gas hawg, I learned it the hard way. Get an oil filled heater from wally world for 40 bucks and it works like a charm.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 11-26-2013, 07:02 PM   #5
If its plugged in or generator running you should be fine
Old 11-26-2013, 07:07 PM   #6
Love My Sunseeker
DXSMac's Avatar
I second the oil filled heater. If you are plugged into a 20 amp, (and not using ANY OTHER APPLIANCES ON ELECTRIC) use a 1500 watt for main part of RV (pulls 12.5 amps) and use a small 400-500 watt oil filled (3-4 amps) in the bathroom. The small one in the bathroom will keep the bathroom toasty. Put the frig on propane if you have to.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 11-26-2013, 07:53 PM   #7
Dijoeboss's Avatar
I was just concerned about using the heater/propane etc with coach inside storage facility. Just wanted to keep it somewhat mild temp wise until tomorrow afternoon!
Old 11-27-2013, 07:23 AM   #8
Where will the heat come from if it's plugged in or generator running?
Old 11-27-2013, 07:29 AM   #9
I don't see a problem with running the heater inside the storage facility especially for a couple of days. The problem with running the heater is that it will go through your propane bottle really fast. I went through my 24.5 gallon tank in a little over a week. I set it to 50 for about 4 days, and since my wife is cold blooded and wanted to organize the inside, I turned it up to 65 and a couple days later it was empty. I went and got an oil filled and cranked it to max overnight with temps below freezing and the next morning it was nice and toasty inside the coach. I then dialed it back and it kept it warm. I'm going to store if that way for the winter.
Old 11-27-2013, 07:58 AM   #10
Old Enough to Know Better
gasman6674's Avatar
Lets do the math, 1 gal of Lp is 91,500 btus, Your furnace is usually 30,000btu per hr full flame so if your furnace BURNS for 3 hours you will use approx 1 gallon of gas. A full 20# cylinder holds 4 gallons, 30# 7 gallons and a 40# 9.25 gallons. Keep in mind if you keep the tstat low it will not burn as much. If you store it inside a building it exhausts co the owner may or may not appreciate you doing that.
Regards
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
