Old 06-15-2013, 06:53 PM   #31
KrohnWE's Avatar
Originally Posted by prairiecamper View Post
All good info posted here, Ok a quick way to check the converter, dis connect the - negative battery cable the one attached to the trailer frame. plug into a 110 volt power supply, are the 12 volt lights on, normal brightness? If they are converter is producing 12 volt power, now connect battery neg cable, using a VOM ( volt ohm meter) check voltage across the battery, should be around 13.5 volts, if yes all is good. If no check fuses or get into Herks troubleshooting guide! Good luck.
Will this "quick check" work for batteries in parallel as well?
KrohnWE is offline   Reply With Quote
Old 06-15-2013, 08:01 PM   #32
Did the problem ever get solved?
msham87 is offline   Reply With Quote
Old 06-15-2013, 09:40 PM   #33
Denver, CO
garbonz's Avatar
yes
2017 Fuse 23T
Old 06-15-2013, 11:21 PM   #34
KrohnWE's Avatar
Originally Posted by garbonz View Post
yes
Thanks!!
Old 06-19-2013, 02:31 PM   #35
Thanks to all. Had found converter. Checked where it plugs in with trouble light ... 'shore' power getting to converter (& also checked fuses on converter and they are good).
At the moment I'm not sure 12 volt power coming out of converter (haven't had chance to test any lately).
Will try the neg. ground disconnect as suggested to see if converter outputting 12 volts. Suspect converter needs replacing, but also possible that the 'BRIT' switch (shore vs. generator vs. battery) got fried.
The .pdf manuals, comments, etc., have been helpful folks!
Hope to work on it this weekend.
Chuck
ckbdk is offline   Reply With Quote
Old 06-29-2013, 07:45 PM   #36
OK, thanks everyone. Long delay in work due to major car accident (me) and surgery (wife). Finally able to replace converter today, and battery seems to be charging, so hopefully the problems are behind us. Thanks for all the tips.
Chuck
