Old 07-10-2016, 07:30 PM   #1
Safe t alert
SAFE-T-a ALERT carbon monoxide/propane gas detector: 2005 Georgetown. Have replaced it several times. Just alarms for no reason. There is no propane leak as we have checked all options. Anyone else experienced this
MRCAT is offline   Reply With Quote
Old 07-10-2016, 07:47 PM   #2
banda's Avatar
Yes that seems to be a common problem. Sometimes it is caused by low voltage from the battery.
banda is offline   Reply With Quote
Old 07-10-2016, 08:01 PM   #3
Flybob's Avatar
What is the battery voltage? If the voltage drops below the level needed to operate the detector, it will alert. If you leave the house battery connected and the unit is not powered ( so batteries are being charged) for more than a week or two, it will draw the battery low enough to set off the LV alarm
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 08:12 PM   #4
Citrus County, Fl.
GL1800Rider's Avatar
While it is alarming, hook up to shore power. If it stops it the batteries
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-10-2016, 08:45 PM   #5
Newellri's Avatar
Mine would get battery gas off changed to sealed battery's and it quit.
Newellri is offline   Reply With Quote
Old 07-13-2016, 05:46 PM   #6
Had weird experience with my safety-alert. This was a new one old one that was replaced was in the coach for14 years. installed new on in april took the rig to Ft Myers, then Lazydays then mims and for 11 days straight like it was on a timer it beeped a soft code at exactly 12:01am battery voltage 13.71 volts took it back to camping world and replaced it
never happened again. It was not a true Alarm jst a soft tone.
aw12691 is offline   Reply With Quote
Old 07-13-2016, 07:16 PM   #7
Puppy sets off alarm
Just in case you have a pet. Our 6 mos old collie lays in the hallway next to the propane alarm and lays again test button. So at 2 am he sets off the alarm. It has happened 3 times. Now we put trash can in front of button. No loud alarms now. Good luck safe travels.
Donamac is online now   Reply With Quote
Old 07-13-2016, 07:55 PM   #8
No pet or any chemical near alarm I think it has a buit in timer
it went off for 11 days straight at the same time every night (12:01) till I got home I checked attery voltage shut off the propane checked for leaks replaced the Alarm and
THE Motorhome. went from 01 georgetown to a 2011 georgetown.
