06-23-2013, 10:21 AM
Safe T Alert CO/Propane Detector Problem
Has anyone had an issue with their detector going off? Mine did this in Florida numerous times over the winter and then stopped until now. It is going off every 5 to 10 minutes. Does anyone know where the fuse would be on the Georgetown XL 378? Please help!
06-23-2013, 10:36 AM
Could be a sign of a low battery???
06-23-2013, 11:19 AM
On my 378 it's under the steps. Sounds like low batteries.
06-23-2013, 02:21 PM
Make sure your battery's are not out gassing. Check that none are not low on water. We had that problem and it was a bad battery. When they were replaced our detector was fine.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
06-23-2013, 04:10 PM
Tim & Lisa Trempert
Ditto. It can be very dangerous and one person had their batteries blow up. If you feel the batteries while charging and one is warmer than the other then that also can mean an internal short in the batteries. A new set of batteries made mine all better.
Tim & Lisa
2011 Georgetown 350
06-23-2013, 07:23 PM
We had a battery blow up when our Georgetown was still under warranty. We had a problem with the alarm and had an appointment with a dealer to have it looked after. We were away and came back to the RV Park and found a battery had blown up. I called Forest River they had the dealer bring out two new batteries and we have not had an alarm since.
2008 Honda Fit
Protect-A-Tow
06-23-2013, 09:05 PM
10Isola
I too am having this issue. I've been plugged in to shore power all weekend. Shouldn't this take away any possible link with it being a bad battery. Since its hard wired and tied in to other components how can I disconnect this thing without it killing any of my other utilities. We are camping for the week, and I just want this thing to stop going off.
06-23-2013, 09:18 PM
I had ours plugged in and had a bad battery. That was out gassing and setting of the alarm.
2008 Honda Fit
Protect-A-Tow
06-23-2013, 09:46 PM
Actually on shore power the batteries are on "trickle charge" or a little more than trickle. As they age they put off more gas, like hydrogen sulfide which will make its way past the steps and cause the propane alarm to go off. Even more than just in storage. Another cause I found with the oven on low or pilot, enough gas can accumulate from poor combustion to set off the alarm, happened just last night! Both events being alarmed is a good thing.
06-24-2013, 07:49 AM
Check your 40 amp fuses too
06-24-2013, 02:52 PM
If it's five years old or older it probably need s to be replaced. Had the same problem on my 360. Meathead from CW told me to just cut the wires, I did, it stopped the noise and also stopped the flow of propane, no cooking no heat. Just replace it.
06-24-2013, 08:01 PM
Tim & Lisa Trempert
Press your battery disconnect switch and the batteries will no longer charge but you'll still have 12v from the converter.
Tim & Lisa
2011 Georgetown 350
06-25-2013, 08:06 AM
two screws hold the unit in. Take the unit out far enough to see the back of unit, it has a replace by date, you did not mention how old your rv was, so your detector could be dying. It is wired to 12vt system and on some models has a propane shut off wired to it. If the detector is alerting, then you cannot use propane, cooking or heat or fridge if not plugged in. Hope this helps. Low Battery is most common issue. Good luck.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
06-29-2013, 10:30 AM
Thanks everybody, I am going to check the batteries. I have a 2013 so they are not a year old yet but that doesn't matter. We are plugged in all the time because we live in here full time.
06-29-2013, 11:03 AM
I had this happen on mine sitting in the backyard; went outside on the back porch and heard a fast beeping noise coming from the camper. Went in, and reset the little button, and it quit. This happened 2 more mornings, and I told the wife about it, and she noticed the gas oven knob was on slightly, she was in there cleaning after a trip, and even though I had the gas tanks shut off, I guess the gas still in the lines made the detector go off. MORAL OF STORY; There is always a reason for the warnings!! Randy
06-29-2013, 11:04 AM
My 2011 came from the factory with new batteries that died in less than 2 months and they would not take a charge. FR sent two new batteries.
08-16-2016, 07:13 AM
I have the 35 / 742 Safe T Alert. The propane alarm was going off about every 3 weeks recently more often. I turned propane off at the tanks but still goes off. A quick question. Should both lights be green? Right now the CO light is solid green and the propane light is off.
08-16-2016, 04:05 PM
LP Alarm
Just a note to inform everyone that has the safe t alert 35 742, it may go off due to your black water tank being full due to the gasses that may escape the toilet. It happened to me.
08-16-2016, 05:08 PM
How do you know it was black tank? Can be hairspray, cleaning products or just a plain malfunction.
08-17-2016, 08:53 PM
They are only good for 5 years just replaced mine, it was 61 months old. It had caused trouble for 6 months. Ordered one off amazon. Remember it needs two extra white wires.
