Old 07-25-2016, 05:15 PM   #11
camaraderie's Avatar
Originally Posted by Carmen View Post
consider the Roadmaster RSA reflex...cheaper and a very easy install
That's what I have and am quite happy with it for a lot less $$:
RSSA - Reflex Steering Stabilizer for Class A Motor Homes
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 07-25-2016, 05:29 PM   #12
Many thank.
Did you also install the Roadmaster Anti-Sway bar to the rear axle?
Tam & Ha
Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
2016 Nights Camping - 6 nights and 2 shake down and love it...
tamdle is offline   Reply With Quote
Old 07-25-2016, 06:12 PM   #13
Originally Posted by tamdle View Post
Many thank.
No...but I know I would benefit from one... just a bit too pricey for the few times I'd appreciate it to make me open my Scottish wallet! I think it would make a real difference on some roads in in some cross winds but 90% of the time...I just don't need it....but I'm a bit shorter than your rig...so you may find a greater need. Good luck!
________
Cam
Old 07-25-2016, 06:31 PM   #14
Thank Cam!
Tam & Ha
Willis, TX
Old 07-26-2016, 12:35 PM   #15
Originally Posted by NewEncounter View Post
I have the Safe-T-Plus and driven about 15,000 miles using it and 3,000 miles prior without it. Driving with the Safe-T-Plus has made quite a difference on my comfort while driving. Semis and busses don't rattle me. I drive with the palm of my hands on the wheel and do not have to use much pressure to stay in my lane even with cross winds. Since I have not driven the other systems I cannot comment on them, but I am certainly pleased with what I have.
Thank Andre,
Did you only install the Safe-T-Plus only or have the rear axle sway bar for your 37 foot RV to get the coach stable.
Tam & Ha
Willis, TX
Old 07-26-2016, 01:27 PM   #16
NewEncounter's Avatar
Actually, the 1st thing I installed was te Tiger-Trak. What a difference that made. I felt there was still something I could do to improve the driving comfort. This is when I installed the Safe-T-Trak. At that point I felt very comfortable in the driver seat. I would not own another one without these 2 pieces of equipment.
André Lizotte
Coachmen 37TZ 2014
flat towing 2014 Honda CR-V AWD
NewEncounter is offline   Reply With Quote
Old 07-26-2016, 01:34 PM   #17
Many thanks Andre!
Tam & Ha
Willis, TX
Old 07-27-2016, 03:34 PM   #18
Land of the Midnightsun
jjSpeedwagon's Avatar
I just installed the safe t plus today on our new concord 300 DS. Wow. What a difference. Night and day. Test drove only 20-25 miles but it's a one handed driver no dought now. Trucks passing me before didn't blow me off the road but I knew they were there. Now it's no side movement at all. I'm impressed and that's hard to do with the after market junk out there
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-27-2016, 08:28 PM   #19
Originally Posted by CharlieS3 View Post
I added the blue ox this year, prior to a 14,000 mile trip to Alaska, on my Coachmen 39 foot Sportscoach. I did the install myself, but it is heavy and a second pair of hands is nice .
I have been surprised how much I have used and appreciated the trim function. It has made long drives less fatiguing. I used to routinely get a back muscle pain,which I now realize was because I was often holding wheel pressure. That has completely disappeared. I have used it in both high winds conditions and also just to add a little trim on crowned roads. It works great. I also used to stop after 200-300 miles due to fatigue. I have driven several 500 mile days quite comfortably on this trip. I'm just getting ready to drive back from Alaska and am glad I have this.
The trim makes small adjustments easily, just a tap of the button is usually enough. To make a large adjustment, such as very high wind,you may need to make the adjustment while going around a bend in order to get enough.
I have no regrets about this purchase and would gladly pay the difference in price for the trim function.
Hello Charlie,
For your 39 footer, beside the Blue Ox steering stabilizer, did you install any rear axle sway bar or any sumo-spring to stiffen the chassis?
Tam & Ha
Willis, TX
Old 07-29-2016, 07:51 PM   #20
We have the roadmaster installed but had it installed immediately after our purchase. I don't really have much road time to compare it to. Price was right and I don't feel like I'm getting pushed around while driving so I guess it's doing a decent job.....
Melvinson404 is offline   Reply With Quote
blue ox
