Originally Posted by kenandterry
How about using decorative washers with screws into the ceiling material (hopefully some kind of wood) above the ceiling covering which you say is starting to sag. With the proper pattern spacing, it could look like a tufted ceiling.
Washer style suggestions......like plastic Rosetta’s?
We had the same problem with our 2011 378. I pulled the vinyl out of the side wall and from under the divider strips, used a spray headliner adhesive and pushed it back in to position. Did that in 2013 and it is still up.
One person on here posted pictures of their padded ceiling that they put up with a Rosetta pattern screw. The spacing they used looked very nice and it would pass as a factory job., I don’t know if you could find it in a search for “padded ceiling repair”. Be good if you could and possibly contact that poster.
Good luck. Oh, by the way, there is a thin plywood under the vinyl, the ply is bonded to foam board. It will hold a screw if you don’t over tighten.
Safe Travels.
