Old 07-11-2016, 03:46 PM   #1
Sanitizing Water Tank
So, how do you get bleach in to the water tank to sanitize it? My old TT had a gravity fill location that I could use a funnel.
I saw somewhere that you connect your hose to the tank fill connection then fill the hose with bleach and then connect the hose to the water source and turn it on? Anybody try this and how much bleach did you get everywhere except in the hose?
________________________
2017 Georgetown 364
2011 Dodge Grand Caravan
Stymie71 is offline   Reply With Quote
Old 07-11-2016, 03:58 PM   #2
slide5r4fun's Avatar
That is how we add bleach to our tank when sanitizing. Just use a funnel to add the bleach to a hose. Connect the hose and SLOWLY turn the water on. No mess
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 07-11-2016, 04:21 PM   #3
chrisbailey13's Avatar
+1 I just fill the hose with bleach and connect it to the water supply to sanitize.
2014 Georgetown XL 352QS
2013 Days Camped-10 (in a rental)
2014 Days Camped-52
2015 Days Camped-53
2016 Days Camped-51
chrisbailey13 is offline   Reply With Quote
Old 07-11-2016, 04:40 PM   #4
Once you 'push' the bleach into your fresh water tank, you will continue to add enough water so that you can use the on-board pump to pump the bleach solution throughout the entire system.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 07-12-2016, 02:34 AM   #5
Do Georgetowns have a water bay where you can suck in antifreeze, have an outdoor shower, AND have the water inlet all nearby?
If so, I used a five gallon bucket to make a bleach/water solution (1/4-cup to every 10-15 gallons of my FW tank capacity).
I then use my antifreeze inlet to suck in from that and the outdoor shower hose to the FW tank fill.
Works a treat.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 07-12-2016, 12:42 PM   #6
Or just buy a small portable water pump, I got one from a local hardware store. Have it stowed in a small plastic storage tote and take it with me.
DuncanM
2014 Georgetown 335DS
Lincoln MKX toad
DuncanM is offline   Reply With Quote
Old 07-12-2016, 05:01 PM   #7
I am not aware of a winterizing antifreeze induction pump/hose on my unit. Doesn't mean it's not there, just not aware of it. However, I do have an outside shower.
So, just hook up the hose from the shower head to the fresh water tank fill connection and fill the tank from there? Surely there are some adapters to make this connection?
2017 Georgetown 364
Old 07-13-2016, 10:37 PM   #8
At your water pump it will have one hose coming in from fresh water tank, and a second hose T'd off that is not attached to anything. There is a valve on it that lets you select the water source. The hose that is not attached to anything is the winterizing hose, you pull it out of the cubby and put into a bottle of antifreeze, then use pump to feed into the water system. So if you use that hose in a large container of water or whatever you can run that through the system to the outside shower, then hook shower hose to fresh water tank fill to top up the tank.
To me it was just easier to have a small water pump instead of going through all this.
DuncanM
Lincoln MKX toad
tank, water, water tank
