I have been looking on FR website at my owners manual for instructions on how to sanitize the fresh water tank. can anyone tell me if there is away to stop the bleach water going into the ice maker of the fridge also how do I stop the bleach going into the hot water tank.
Thank you
Don't know about ice maker but I'm sure there must be a shutoff valve on that line. As for water heater just put it in winter bypass mode and no bleach will run through there.
Pull the cutoff valve under the sink that goes to the fridge, this will turn off water. Put both hot water tanks in winter bypass mode and you're good to good!
My 364 has an oven. In the cabinet to the left of the oven there's a carpeted divider wall. Behind that wall is the shutoff valve for the refrigerator line. You don't have to remove the wall--it sticks up high enough to reach.
