Old 06-16-2016, 09:31 AM   #1
Satellite and over the air
How do hook up to watch sat on main tv and watch Ota on bed rm tv?
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 06-27-2016, 10:31 AM   #2
NCCoachMan's Avatar
A great questions. I'd love to know the answer too.
NCCoachMan is offline   Reply With Quote
Old 06-27-2016, 11:14 AM   #3
bubbles's Avatar
Unlike my current RV in a previous RV I had a selector box similar to this. There were no splitters installed which required all the TV's be tuned to the same input. If one wanted to dig out and remove the splitters, install coax extensions and route them direct to a box like this all the TV's could tune to whatever input is selected for that TV independent of what the others are tuned to. Oh well. Maybe there's another way.
Old 06-27-2016, 11:31 AM   #4
Forbes's Avatar
If you are using Dish 712 or their RV unit connect the RV antenna to the ANT IN on back of receiver, then in main menu find Local Channels and have the receiver scan for stations. You will then be able to use your SAT receiver remote to watch locals. You may or may not have to turn the RV Antenna amp off, I don't also your set up may require you to use one of the 1 x 3 split units and don't forget to raise your RV antenna and lower it when done.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 06-27-2016, 11:37 AM   #5
Pickin' & Campin'
Not sure how the Georgetown is wired but my 5th wheel has two ports in the bedroom.
One for satellite the other for cable/antenna.
You simply connect the coax (to the TV) to the one you want to use.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-27-2016, 12:13 PM   #6
bubbles's Avatar
If it's all coax I think I would be installing me an A/B coax switch in the bedroom. One time connection for both.
Old 06-27-2016, 02:57 PM   #7
Pickin' & Campin'
That would certainly work.
Old 06-27-2016, 03:14 PM   #8
It's like let's one cable and splitter and 3 tv's and have everyone watch the same programs
My other mh had a cable for each. The designers are not campers?
So frustrated!!
Don
Old 06-27-2016, 03:47 PM   #9
Happily Retired Member
It is cheaper to do it the way they do.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 06-27-2016, 05:49 PM   #10
Ddubya's Avatar
Mine has separate wall plates for satellite and over air/cable
Ddubya is offline   Reply With Quote
satellite
