Originally Posted by bubbles
Don't know what model GT you or Gohawks have but here it a coax interface dwg for a GT360. The Movie Vision (MV) device is the same interconnect in my GT378. I use a straight shot from the carryout to the sat receiver by disconnecting the park cable input to the MV and connect to the sat receiver. Splitters and such after the sat receiver does not matter.
Nice drawing, from personal experience, I can confirm that my 2015 335DS is wired exactly the same as the drawing. You can try running through the park cable input in the basement and hooking the receiver up by disconnecting the "cable in" coax and routing that to the receiver. If the receiver has RF out to TV (coax "F" connector) put a short run between the receiver out to TV connector and the "cable in" and you should have whatever the receiver is set to appearing on all the TVs in the coach.
If, for some reason, there is a non satellite compatible splitter in the run from the "park in" to the selector (can't imagine what it would be for?), you could put the receiver in the basement and connect the "out to TV" to the park cable in and get the same results...or you could run the antenna cable through the window as others have said. If you have a coax distribution system, n(i.e. non-HDMI) I would try the cable in first.
