07-30-2012, 05:44 PM
#21
Originally Posted by 87CrewDually
I too have the ScanGauge II for my 05 6.0 ford. No question, if you have a 6.0 diesel you need the ScanGauge. Being able to monitor the oil and water temps is huge on the 6 liter. Running at highway speeds empty on flat land you don't want to see the temps 15 degrees or more apart. If you do, IRS time for a coolant flush and cooler change. Also, the FICM needs 13+ volts and needs to put out 47-48.5 volts or you can suffer from injector coil failure. I also on occassion will check the high pressure pump pressure which requires 500psi just to start the engine.
Simply put, one of the best diagnostic and preventative tools I have.
I have two SC II's linked to each other ! And I get to see 8 parameters all at the same time. My only complaint is everytime I cross the border I get asked why I have these up there and what are they
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
07-30-2012, 05:51 PM
#22
2007 WildCat 32QBBS
I considered doing the same. I heard you're able to piggy back up to 4 units.
For now, the 4 are fine, oil temp, coolant temp, FICM output and trans temp.
08-01-2012, 07:42 AM
#23
Still working on which 4 I want. Currently engine coolant temp, tranmission temp, MPG and engine oil temp.
What is FCIM?
08-01-2012, 09:13 AM
#24
I have the Load, Transmission fluid temperature, MPH (for my US trips), Slip (How much the transmission is slipping), instant and average gas consumption, Distance to empty and one more I can't recall right now.
Yes what is FCIM ? I never watch the coolant temperature .. The needle on the truck's gauge never wavered all this time I had her. Does SCII show a big varience on this ?
08-01-2012, 09:27 AM
#25
On Fords, I believe that the coolant temp is "managed". You won't see it waiver because it freaks people out. It won't go off center until something is seriously wrong, after it is too late for you to adjust.
On my Ecoboost, coolant temp is all over the place. Why? Because the turbos are water cooled. If you get into the throttle, coolant temp can go up 10 degrees in seconds. But the dash needle never changes. You would never know that without a ScanGauge or similar. Could be useful to know if your coolant temps are rising in a mountain climb for example. Might give you a chance to back out of it, if necessary, BEFORE you have a bigger problem.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
08-01-2012, 10:06 AM
#26
Hmmm...you sure about that? I had the Edge on the F150 and it would show a hotter coolant temp while towing. Maybe I'm thinking transmission temp.
08-06-2012, 08:47 AM
#27
2007 WildCat 32QBBS
What is FCIM?
The FICM is on the driver side valve cover on the 6.0 diesel. It's an acronym for Fuel Injection Control Module. You want to monitor a 48 volt reading output to the injectors. If the volts are low for a period of time injectors will start to fail. There are 4 resistors inside that become unsoldered causing this condition. It's a big $$ item if replaced, or take a couple of hours to repair it yourself as long as you know what to look for.
08-07-2012, 10:06 AM
#29
I originally had a scanguageII on my Ford V10, I then purchased a diesel pusher with a 330HP Mercedes. I couldn't use the scanguageII on the diesel because it doesn't have a OBDII plug but a different type of plug that is used on diesel chassis. It works great. I was thinking about selling the scanguageII but I am thinking I could use it in tandem with the scanguageD since I think the only difference is the plug. Anyone know if this is possible?
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
08-07-2012, 11:16 AM
#30
2007 WildCat 32QBBS
I would contact ScanGauge direct with that question.
08-07-2012, 11:59 AM
#31
Originally Posted by Iggy
I had considered the same thing. I got the Scanguage II because I didn't want to be switching back and forth between the GPS and Ecoroute. Plus, the Scangauge allows me to display more parameters like Boost, Transmission Temp, etc. I did a lot of research and don't think you can go wrong with either. I would also check out the Ultragauge. It's like $59 or so and seemed to be on par with the other 2.
08-07-2012, 09:49 PM
#32
I see most of you have the Garman EcoRoute installed on your trucks.
Has anyone here used it on any Georgetown F-53 Ford Chassis with the V10?
04-19-2013, 10:14 PM
#33
Which guages do you use?
Radiator temp?
Transmission Temp?
Instand mileage?
I haven't bought one but still considering it for my 2012 Georgetown.
