Old 04-11-2015, 10:17 PM   #1
CheckSix's Avatar
School me on the Rear, Left & Right Cameras
After the sway bar install, I drove home in the dark for the first time. I noticed when I turned the headlights on, the camera monitor switched from rear view, to left view. Then, when I turn right with the blinker, the rear view shows up but it blinks the monitor display, in unison with the blinker. The right camera does not work anymore. IIf I turn the headlights off, the monitor goes back to the rear view camera view and the right camera works correctly with the blinker on.
What am I doing wrong?
2012 Georgetown 327DS--->2015 Georgetown XL 369DS
CheckSix is offline   Reply With Quote
Old 04-11-2015, 10:56 PM   #2
abjb's Avatar
You've got a/some lights burned out or corroded, check them all.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-12-2015, 10:36 AM   #3
silver's Avatar
Were the cameras installed by the factory or are they after market installed by a previous owner? Almost sounds like the trigger for side cameras are tied into marker lights rather than directional. After market install make this mistake as side markers are easier to cut in to.
silver is offline   Reply With Quote
Old 04-12-2015, 10:39 AM   #4
Iggy's Avatar
X2
Don't make it more complicated. You do have a bulb burnt out. Check all lights.
Old 04-12-2015, 11:01 AM   #5
CheckSix's Avatar
It's factory.
I'll check the light bulbs today.
Thanks!
Old 04-12-2015, 04:32 PM   #6
CheckSix's Avatar
All light bulbs on the exterior are working. When I checked it today, after turning on the headlights, it switched from rear view, to left view but when I turned on the fog lights, that switched it back to rear view. It then behaved what I consider normally, WRT turn signals and camera views.
Is this system prone to gremlins? Seems so.
Old 04-12-2015, 05:23 PM   #7
Bubbamace's Avatar
Originally Posted by CheckSix View Post
All light bulbs on the exterior are working. When I checked it today, after turning on the headlights, I switched from rear view, to left view but when I turned on the fog lights, that switched it back to rear view. It then behaved what I consider normally, WRT turn signals and camera views.
I have the same system installed at the factory. Turning on the headlamps and fog lamps do not affect my system. When I turn on the left turn signal, the left camera comes on and then the same for the right signal, the right camera comes on. When I back the rear view camera comes on. I can go in the menu and set the rear camera to be on at all times when I'm travelling if I'm interested in what is happening with a trailer or toad. I believe that something is not wired correctly or perhaps a bulb is out (I wasn't aware a bulb out could affect the system). I did find one of the camera wires off one time and reconnected it. Left camera, but it just wouldn't work. Also, I found one wire off behind the camera/radio system. the wire connector had fallen out of the radio system, so you might check there. I travel some rough roads out in the desert and I'm sure this caused the problem. Good luck and let us know what happened.
Bubbamace is offline   Reply With Quote
Old 04-12-2015, 10:48 PM   #8
abjb's Avatar
Ours works like yours, the sockets get corroded. Every time I get a chance I use contact cleaner and apply dielectric grease
Permatex/Dielectric tune-up grease 22058 at AutoZone.com
to a few bulbs/sockets. last year I had to do 5 just to pass the state inspection.
Here are a few threads with similar problems.
Camera not working
Side cameras - 360
Side View Camera
2012 Georgetown 360
Old 04-13-2015, 10:20 AM   #9
Bubbamace's Avatar
By the way, when I found the camera line unplugging, I didn't remove any screws or panels. I was able to lay down and see the back of the receiver/stereo and observe the plug that was out. That simple for me.
Old 04-13-2015, 11:41 AM   #10
CheckSix's Avatar
In my case, everything is plugged in and all bulbs are working. The camera monitor system seems to do what it wants sometimes, until I interrupt it with fog lights or headlights being switched on or off.
I'll have to get into the system and see how the preferences are set up.
