Old 03-23-2014, 08:31 PM   #11
We purchased the expensive rails at babiesrus. They work wonderfully. And easy to out up and down. Am I the only one that thinks the way the ladders are, that they are hardly usable? Not to mention hard to make the beds as well.... (We own a 351ds)
Campingmomx4 is offline   Reply With Quote
Old 03-23-2014, 08:41 PM   #12
phat phrog stunt crew
Otr semis use both seatbelts and netting for the upper bunk and seatbealts only for lower berth. Seatbelts meaning lap belts. Maybe something like that will help. Julianos is a good source for lapbelts as would be most auto restortion dealers. Depending on their age, the netting may be a better choice.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 03-23-2014, 08:45 PM   #13
MI Camperz
bodzcampers's Avatar
I lean toward this suggestion...just as a "think safety" RN.
I wouldn't go netting as fingers and toes can get caught....seen it bad.
I would support 100% something truly kid approved. Restraining anyone is dangerous, but so is a fall. Using something make-shift, not kid approved, is asking for unintentional accidents. I would also support making a bed on the ground till they are old enough to handle it.
Just do research. I would also support having a ladder available rather than having them invent ways to get down when you're not around to go potty or whatever.
Lynn
MI Camperz
bodzcampers is offline   Reply With Quote
Old 03-24-2014, 10:06 AM   #14
Here is the one we use for the top bunk for our 6 year old:
For the lower bunk for the baby:
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 03-24-2014, 11:38 AM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
Originally Posted by kho6658 View Post
This is what I purchased and works fine.
Dex Products Convertible Crib Bed Rail 33" x 16" : Target
We use the same or similar. We didn't need all the pieces, and it has worked quite well.
Sent from my Samsung Note 8 Tablet using the FRF Android App!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-01-2014, 01:47 AM   #16
Wildland Firefighter
We made a double rail unit out of pine 1x3's. 2 horizontal boards screwed to 2 vertical boards. The verticals are screwed into the bunk face board and a small L bracket attached to the wall edge to keep it from wobbling. Works well. Never had a fall off.
Gordon and Dawn is offline   Reply With Quote
Old 04-01-2014, 10:25 AM   #17
jimacamper's Avatar
Found a crib rail - as opposed to a bed rail that is working. The only other issue is the lip of the bunk. Trying to be careful not to put too much outward pressure on it. May put a piece of wood there to offset the pressure and raise the rail.
Georgetown XL 350ts
Past:
LivinLite Quick silver
Coleman 12' Pop up
Jayco X23B
jimacamper is offline   Reply With Quote
Old 04-01-2014, 10:31 AM   #18
DAISY BOYKIN's Avatar
Wheeeeeeeee----------
Sho glad We do not have any little ones
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-01-2014, 10:43 AM   #19
Arefbee's Avatar
I'd say standard bed rails from Wally World might work. Can't find a good image of the bunk area of your rig on the interweb so just guessing.
I would strongly recommend against using the bunk in motion. A good old child safety seat is the only safe way to go for snoozing then. The rig may be big as a truck but it can stop with a lot of G's in and accident and having the young one properly secured is the only way to go.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 04-01-2014, 11:51 AM   #20
We use these for our Sunseeker under the fitted sheet
http://www.amazon.com/Honest-Foam-24...ref=pd_cp_ba_3
GJones is offline   Reply With Quote
bed
