Old 09-26-2010, 10:25 AM   #1
Lawfive's Avatar
SeeLevel Gauge Install??
Has anyone installed Seelevel gauges to replace the iffy factory gauges on fresh, gray, and black tanks? I would love to hear your experience.
2007 391TS UFO Chassis
Lawfive is offline   Reply With Quote
Old 09-27-2010, 10:07 AM   #2
ronhanson's Avatar
I have not done it on my Georgetown but did it to my popup I had before. They are very accurate and do not give you the fouled readings.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 09-27-2010, 12:39 PM   #3
Just did it on my 2010 Roo was very easy and used the same wiring from the old unit.
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
Old 09-27-2010, 03:28 PM   #4
Seelevel gauge install
I have a 2009 Georgetown 373 and I looked into getting the SeeLevel gauges.
Due to the odd shape of the tanks in my unit the gauges would never give a true reading and I would have to have a conversion chart.
The free water tank is L shaped with the L hanging over the center rails of the RV.
The black and grey tanks are even weirder. They are taller on the drain side than on the other. They are also T shaped top to bottom to rest on the steel support bracket that goes all around them.
I talked to the manufacturer and they said they expect the tanks to be rectangular for the numbers to be accurate.
I could have handled having a conversion chart but...
They also said the sensor has to be at least 1" away from any metal and with the bracket all the way around the black and grey tanks I couldn't find a place to put them.
So I gave up.
snorman is offline   Reply With Quote
