Old 09-03-2013, 09:29 AM   #31
Iggy's Avatar
FYI
I just email Progressive Dynamic about the PD9270 Inteli-Charger I have in my Georgetown and wanted to know if the charger is capable of charging either Lead acid or AGM batteries. Her eis the questiona nd reply.
Question
I have PD9270 charger in my motorhome. I have two lead acid batteries that are presently installed. If I install AGM batteries does the charger know or care about charging cycles?
Answer from manufacturer
The charger comes from the factory set for AGM and Lead acid.
13.2 volts Storage mode
13.6 volts Regular mode
14.4 volts Boost mode
Service Department
Progressive Dynamics
8A.M-12PM & 1PM -5PM EST
Phone 269-781-4241
FAX 269-781-8729
Old 10-18-2013, 04:47 PM   #32
BillMFl's Avatar
Here is what I have done. My standard lead acid batteries boiled over slightly several times during the first year (2012). My Trawler needed new house batteries so I took the MH batteries out and put them in my boat. Then I put 2 new sealed Group 27 lead acid batteries in the MH. No problems so far this year and no boiling over. During storage at home I flip my supply breaker off or on several times a week so the batteries won't get too much or too little charge. Plan to get a battery minder next. Had AGMs in my boat and don't personally think they are worth the added cost. Just my opinion for what its worth. About the same as my CD rates probably.
BillMFl is offline   Reply With Quote
Old 10-18-2013, 04:53 PM   #33
Denver, CO
garbonz's Avatar
Originally Posted by Iggy View Post
I will start this off with
Sears who sell Diehard Batteries
They have 3 models and all 3 batteries are exactly the same price of $108 plus old battery exchange.
They are lead acid and are the same physical size.
Now here is the difference
Model 33027, 750 Cold Cranking Amps with 135 amps reserve, 50 lbs
Model 50727, 825 Cold Cranking Amps with 140 amps reserve, 49.5 lbs
Model 50527, 750 Cold Cranking Amps with 140 amps reserve, 48 lbs
As you can see they all are close but not sure which I would pick.. Do you?
None of them if I was intending to dry camp, any of them if I was going electric site to electric site.
Need 6 or 12 v golf cart batteries like Trojans or Deka or etc. for dry camping.
2017 Fuse 23T
Old 10-18-2013, 05:08 PM   #34
Denver, CO
garbonz's Avatar
Originally Posted by johnnypal View Post
I like my new 6 volt golf cart batteries hooked in series. They are taller , heavier and more expensive than the twelves but I am told they will last a lot longer.
X2. I got two GC10 Deka's for $115 each and they are ROCK SOLID. I would have got some T105 Trojans but the industrial battery supplier hade and recommend the DEKA's.
2017 Fuse 23T
Old 10-18-2013, 06:56 PM   #35
Batts-toy's Avatar
X2, none of these, they appear to be dual purpose batteries and I for one won't go there. Amp reserve does not equal Amp hours. The Ah will be too low for my liking.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
battery, replacement, select
