Old 01-19-2016, 05:25 PM   #1
BillMFl's Avatar
Servicing Generator
I have been changing oil and filter each year (low hours). What other service items need to be done other than running it periodically.
BillMFl is offline   Reply With Quote
Old 01-19-2016, 05:52 PM   #2
The Onan - Cummins manual gives a few other things like spark plug and air filter replacement. If you don't have a manual you can download it from their website.
Another example, the manual for our 4000 watt gasoline generator says to remove the plugs from the bottom of the muffler and run it under load to blow the carbon out. I don't remember the hours.
They recommend removing the head and scraping carbon off at 500 hours. That could be a pain.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 01-19-2016, 09:39 PM   #3
Changing fuel filter is a must every 3years minimum
daddio is offline   Reply With Quote
generator
