Old 10-03-2016, 06:58 PM   #1
sewer smell
just started living in our gt 378 xl been in it 7 days and all of a sudden we are getting sewer smell out from under the kitchen and bath sinks. i dump every 3 days first black tank then gray following with a 10 minute black tank flush. any ideas. thanks ron and debi at the granbury rv ranch
rwehba is offline   Reply With Quote
Old 10-03-2016, 07:05 PM   #2
Broadway Joe's Avatar
You have whats called a "Studer" valve which is a one way vent under each cabinet, after a while the flapper dries out and no longer seals properly. Look up air admittance valve, which are fairly cheap to replace.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 10-04-2016, 05:44 AM   #3
360true's Avatar
I suggest that you should dump your gray tank as often as needed, but only dump the black when it is at least 3/4 full. You want to have enough gravity and water pressure to push out the solid and paper. For the two of us, it is about 7-10 days.
360true is offline   Reply With Quote
Old 10-04-2016, 10:18 AM   #4
JimF's Avatar
Used to have that problem, was cause by my dumping sequence. I leave the grey tank open and dump the black when full. I used to close the grey before dumping the black and would get a horrible smell in the coach. Started leaving the grey tank valve open when dumping black and the problem stopped. Was caused by gas suction when the black tank air relief pipe was under the surface of the blank tank water level. Shouldn't be able to do that but it does.
JimF
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
Old 10-04-2016, 02:20 PM   #5
got it changed
bath was easy the kitchen was almost out of reach unless y got long arms thanks guye ron and debi,,granbury rv ranch
