Old 06-26-2012, 05:06 PM   #1
Unhappy Sewer Smell from furnace vents
Can anybody offer some advice? When I dump the grey water on our Georgetown 378, I get a sewer smell from the furnace vents for a day or two afterwards, without the furnace running. (And on day three, it's time to dump again...) The problem is aggravated when I run the Maxair on exhaust; it sucks the smell from the floor vents into the coach. I taped over the vents, and when I removed the tape the next morning, there were some water droplets evident on the plastic vent. No smell from the drains or around the dump controls on the exterior, and I'm using deodorizer in both tanks. The stench is definitely in the furnace vents.
2007 Georgetown 378
2011 Cadillac SRX toad
Only downside to travelling is missing the grandkids!
PaulK is offline   Reply With Quote
Old 06-27-2012, 08:48 AM   #2
TURBS's Avatar
I have to wonder if your grey water vent that runs to top of the unit has came loose or fallen off your tank?
Do you have heated basement?
Old 06-27-2012, 03:34 PM   #3
The more I research, the more I think that a disconnected vent pipe is in fact the culprit. I've been running the Fantastic Fan to blow air into the coach for a day, thus creating a positive pressure to the furnace vents, and that seems to have dissipated the smell, for now. Still going to have to fix the problem. The issue now will be, how do I get at it on the Georgetown 378 without taking apart the bedroom closets???
As for the heated basement, the coach came with the Arctic Pac, so I'm assuming that the heated basement is part of that package.
2007 Georgetown 378
Old 06-27-2012, 03:36 PM   #4
good luck keep us updated!
SALTY is offline   Reply With Quote
Old 06-27-2012, 04:05 PM   #5
TURBS's Avatar
That's why I asked that means there's a heater vent down below drawing up the fumes.
Post what ya find.
Old 06-27-2012, 04:13 PM   #6
VinceU's Avatar
Also have a 378 and yes compartements are enclosed and a few heated. That gives spaces for odors to collect and come in close proximity to "heat ducts" in your case. It also makes access to the tanks very difficult. I've never done it to a RV but we used to "smoke test" boilers to locate casing leaks. In your case wondering if you could apply smoke or strong (pleasant)odor to the open vent pipe on the roof to force it downwards. This would prove its the vent without major ripouts of walls and cabinets. Another less desireable test is to fill the gray tank till it enters the shower. Thats above the vent tie-in and would result in water coming out the bottom without flooding the floor. Just wondering, lots of expensive exploring otherwise. Still have warranty?
Old 06-27-2012, 04:20 PM   #7
Phat Phrog Stunt Crew
awwall's Avatar
Just a wild guess ...Maybe a rodent has gotten into your vents and died
awwall is offline   Reply With Quote
Old 06-28-2012, 02:45 PM   #8
Definitely a problem with the vent pipe connection. It's just over the water heater compartment, and now I have water seeping out of that area. I'm going back to the dealer I bought it from a month and a half ago. This is far from normal. I'll let you know how things turn out.
2007 Georgetown 378
Old 06-28-2012, 06:37 PM   #9
VinceU's Avatar
Bingo, a check of mine has the vent.terminal just ahead of the rear ac on curbside, black appears 3' forward on street side. They align roughly with their tanks. Beats lots of rip outs.
Old 06-28-2012, 07:25 PM   #10
VinceU's Avatar
I just sighted the vent extending to the roof located in the w/d locker in the bedroom. If you got the w/d hookup as an option they tied a trap into this vent/drain. All this is hard piped, good thing because the open power panel is just below mounted to the floor. I have to assume just below the floor is a connection to the grey drain tank probably soft like hose and clamps? The water heater is just below also. Can't get into the compartment save for hand hole access. Most likely that's where fitting is.
furnace vent smell, sewer smell, smell
