Old 06-16-2016, 04:15 PM   #11
DAB2014's Avatar
Shock
I had similar situation. Was getting 23+ volts when checking with meter from MH to probe in ground (dirt ground). Eventually went to 70+ volts. Only happened when plugged in at home to 15A thru adapters. Eventually determined it was a bad ground (open) connection on female end of 30A extension cord. Replaced female connection and all is well.
Good luck
2013 Georgetown 335DS
2017 Cherokee Trailhawk
DAB2014 is offline   Reply With Quote
Old 06-16-2016, 05:21 PM   #12
tandem54's Avatar
[QUOTE=Croaker;1229705].
Make sure the ground prong on your extension cord is not missing.
That is what it was on my MH, broken ground prong!
Forest River Lexington Grand Touring.
tandem54 is offline   Reply With Quote
Old 06-16-2016, 05:30 PM   #13
SeaDog's Avatar
X2 what WMTIRE said be very careful
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-16-2016, 06:58 PM   #14
scootingranny's Avatar
Very tragic story. Be very careful Boy, three, fatally electrocuted by touching parent's trailer door handle while standing on wet ground | Daily Mail Online
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 06-16-2016, 07:25 PM   #15
Grounded
Home/house neutral and ground wired together. TTs ground and neutral ARE separate (they are supposed to be separate), sounds like TT missing neutral/ground, check your plug, cord and house outlet. TT is on rubber insulators/tires.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 06-17-2016, 07:00 AM   #16
Wolverine 1945's Avatar
Originally Posted by Trempert View Post
Is it static electricity or an actual electrical shock. I'd be surprised if you're getting shocked through the paint but it's certainly possible. Have you taken an electrical meter with one end to ground and see if you're getting any voltage readings on your camper?
I am guessing static ele is not a problem in Florida ???
Unlike the SoCal desert !!!
Wolverine 1945 is offline   Reply With Quote
door
