Old 06-15-2016, 04:21 PM   #1
siskom's Avatar
Shock when opening door
2014 335 all of a sudden when home and camper is plugged into 30 amps we are getting a shock when touching metal on camper. Help it just started this
siskom is offline   Reply With Quote
Old 06-15-2016, 04:32 PM   #2
Unplug the coach yes this is a dangerous situation. Only if you think its safe to physically unplug. If not turn breaker off from within home.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-15-2016, 04:32 PM   #3
rmac04401's Avatar
You have short in your electric. I had this on my old Fleetwood. The cord got pulled out to far and was shorting against bus bridge in fuse box. I would checke behind your fuse box where it comes into camper then start tracing wires to see where short is.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-15-2016, 04:33 PM   #4
Tim & Lisa Trempert
Is it static electricity or an actual electrical shock. I'd be surprised if you're getting shocked through the paint but it's certainly possible. Have you taken an electrical meter with one end to ground and see if you're getting any voltage readings on your camper?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-15-2016, 04:34 PM   #5
Read this RV Electrical Safety: Part IV – Hot Skin | No~Shock~Zone
Hensley Arrow
Old 06-16-2016, 01:21 PM   #6
Bad ground
markoldin is offline   Reply With Quote
Old 06-16-2016, 01:50 PM   #7
Happily Retired Member
X2 on the bad ground.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 06-16-2016, 01:52 PM   #8
Croaker's Avatar
Make sure the ground prong on your extension cord is not missing.
Croaker is offline   Reply With Quote
Old 06-16-2016, 01:53 PM   #9
wmtire's Avatar
You have a problem. Please read this link that we keep as a sticky in the electrical section from the expert on these situations, Mike Sokol.
I get shocked when touching RV
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 06-16-2016, 02:17 PM   #10
Flybob's Avatar
Shut off the breaker for your water heater and then measure the voltage between the RV and ground. If you have the electric element on and connect power, it will burn out the element and and can short to the frame. If this doesn't fix it, you have a wiring problem and need it looked at immediately.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
door
