Has anyone had trouble with A leaky shower door? The plastic track guides on the bottom of the door keep popping out causing the joins in the door to be partially open.Even when I pop them back the door is still not water tight.
Many here have. Do a search for "shower" or "shower door" as there has been some lengthy threads on the subject. You might find a solution there.
"I can fix it, and if I can't fix it, I can fix it so no one can fix it!" Ed & Wendy 2009 Georgetown 378TS | 1998 Jeep Wrangler | 1998 Skeeter ZX202C
Nights camped in 2009: 53 | Nights camped in 2010: 55 www.nwjeepn.com
ours leaked around the gasket at the bottom of the windows, water ran down the glass and seemed to seep through the gasket i sealed it with silicone and it has helped so far.
