Old 04-21-2018, 09:23 AM   #1
Shower pan woes....
I have noticed the few times I used it....my shower pan sure felt mushy and after reading a few posts on here figured it would be an easy fix. After removing the panel the problem is obvious. They used 3 2X4's to support the plywood (why not use 4?) and one of the 3 was not even resting on the floor. They simply nailed it into the plywood and it hangs down in the open space. There was no support for the panel side of the shower pan either. We could have easily ruined the pan after a few more uses. I find it hard to believe some one did not notice this as they were installing it.
( not sure why the pics are upside down)
ID:	169023   Click image for larger version
2017 Georgetown GT3 31B3
N Little Rock AR
bclinton is offline   Reply With Quote
Old 04-21-2018, 09:36 AM   #2
koller1509's Avatar
My sandpiper was the same way, I cut three 2x4s about an inch shorter then the cavity depth and then slid them in under the pan. I had planned to spray minimal expansion foam in between the 2x4s as I installed them but after dry fitting them the pan as rock solid so I chose not to use spray foam. I also stuffed insulation in all the holes they cut under the pan and it helped when camping in the COLD months.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 04-21-2018, 09:53 AM   #3
That's a good tip on the insulation. I used 4X4 supports cut to where I can barely maneuver it, along with a dab of liquid nails. Put one in the rear and 2 up front after I cut out a filler piece of plywood to put under the Styrofoam.
N Little Rock AR
Old 04-21-2018, 10:00 AM   #4
cavie's Avatar
The more I read about non-quality builds and technology failures on so many RV's the more I'm in love with my 16-year-old 5 er. The interior looks like a new one. The graphics were faded out long ago. I'm making some improvements this year. Outside exhaust range vent. New 320 toilet. New digital T-stat. I removed the 16-year-old satellite dish and TV antenna last year when I coated the roof. I have /direct TV on a permanent site.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-21-2018, 10:06 AM   #5
Just build a Bridge to span the "Opening" and place 2x2 supports from the bridge to where needed under pan,additional plywood may be needed on bottom of Pan also! With your "Upside Down Pic" as a reference turn my advice around also! Youroo!! PS a Dab of Gorilla Glue on all the pieces keeps things in place going down the road!
Old 04-21-2018, 10:11 AM   #6
When you get through gluing the spacers in place fill the opening with expanding foam.
Old 04-21-2018, 10:15 AM   #7
I placed 2 4X4's in the opening. Had some extra cedar and used it along with cutting out a small piece to fill the plywood gap. I figure cedar is not going to expand or contract on me over time....
N Little Rock AR
Old 04-21-2018, 10:41 AM   #8
Denver To Yuma In 90 Days
My previous TT was the same way...
I had to use 2x4's to support the shower floor.
As for the upside down photos...I'm guessing you took them with an iPhone?
2015 Heartland Prowler P292 5'ver
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear axle
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
JohnD10 is offline   Reply With Quote
Old 04-21-2018, 10:44 AM   #9
I took them on my galaxy and even rotated them before uploaded and it still flipped them
N Little Rock AR
Old 04-21-2018, 12:54 PM   #10
WDW
I wouldn’t glue them. I think that if you have problems with the drain and you need to tighten it replace it or make other changes though support pieces might be in your way to maneuver. Something to think about
WDW is offline   Reply With Quote
show, shower
