Old 12-14-2013, 01:16 PM   #11
Iggy's Avatar
Originally Posted by Sbryant View Post
Anybody have any trouble with your side cameras? Our left camera does not work. Turn on left signal and the message on the monitor screen says "no signal". Any repair suggestions on repair?
In a nut shell most problems are a burnt out bulb or a loose ground wire somewhere in your lighting/camera system.
2012 Georgetown XL - 378TS 49,000 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 115 days)
USAF Retired - MSgt
Old 12-14-2013, 01:42 PM   #12
Sent ya PM
RVINSMCM is offline   Reply With Quote
Old 12-15-2013, 03:15 PM   #13
Sbryant's Avatar
A special thanks to RVINSMCM for the info on how and where to look to fix our side camera. Sorry for the delay in posting this info, but this is what we did to make camera work. The camera was not the problem. The connection of the camera to the monitor was.
Hubby removed 6 screws from the panel that the monitor is sitting on and pulled the panel forward out if dash. He could see where the cable was not connected. Simple fix - push cable back into the socket and the camera worked. He pushed the panel back into dashboard and reconnected all 6 screws.
Once again, thanks for the heads up on this problem. Hope this info will help others who might be having same problem.
Sbryant is offline   Reply With Quote
