Old 08-13-2016, 10:02 AM   #1
mr.ken's Avatar
Side cameras don't work
I have a 2010 357 qs and the side cameras aren't working. Has anyone had any issues or know what it could possibly be. All I have done is check connections at the monitor
2010 Georgetown 357qs
2009 chevy hhr
2007 chevy silverado
mr.ken is offline   Reply With Quote
Old 08-13-2016, 02:04 PM   #2
Have you tried the connection at the camera video switch?
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 08-13-2016, 07:39 PM   #3
chrisbailey13's Avatar
Can you elaborate on the symptoms? when you turn on the signal what happens with the camera? does the rear view camera work?
2014 Georgetown XL 352QS
2013-2017 Days Camped-176
chrisbailey13 is offline   Reply With Quote
Old 08-14-2016, 08:20 AM   #4
mr.ken's Avatar
Yes. The rear camera works. If you turn on either signal the screen goes black like it was going to change to a side camera then the rear camera comes back on
2009 chevy hhr
Old 08-14-2016, 01:39 PM   #5
Check your side marker/turn signal bulbs. I have seen that symptom when the a bulb is burned out.
May not be your situation, but it is a start.
Old 08-15-2016, 02:18 PM   #6
mr.ken's Avatar
I will do that.....thanks
2009 chevy hhr
Old 08-15-2016, 07:24 PM   #7
Mr Ken
There is a video switch on the floor just to the right of the gas pedal that the cameras plug into. There's 3 cables in a row that are from the cameras. Left, center and right. You can swap them around while on and see if they will work. They were always getting loose on mine and going black. Just reseat and fine.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 08-16-2016, 09:18 AM   #8
mr.ken's Avatar
Originally Posted by Billr View Post
Mr Ken
Thanks. I will check that out when I get home
2009 chevy hhr
Old 10-12-2016, 08:55 AM   #9
mr.ken's Avatar
Took a bit to get to it. One of the forward turn signals was out. Replaced it with no change. The side turn signals work but both lost their Lens covers. Still searching for a cause
2009 chevy hhr
Old 10-12-2016, 09:42 AM   #10
Iggy's Avatar
Check ALL your side and top marker light and turn signal bulbs.
2012 Georgetown XL - 378TS
