Old 05-29-2016, 05:16 PM   #1
Jphatch248's Avatar
Side cockpit window frames creak badly when driving
I have a 2014 Georgetown 335. The driver and passenger side window frames creak badly while going down the road. Does anyone know a fix for this or perhaps a recall of some sorts from Forest River?
Name:   ImageUploadedByForest River Forums1464560070.442421.jpg
Jphatch248 is offline   Reply With Quote
Old 05-29-2016, 05:59 PM   #2
GABoy's Avatar
When my 2014 351 was in for one of its many warranty repairs they installed anti rattle kits from hehr I believe is brand. It made better but not to my liking. In the end I adjusted those plastic retainers where window closes in frame at top middle and bottom. Then I took a pair of pliers and bent the inner frame towards outside at those 3 points maybe an 1/8" each. Then once close widow the retainers grab the glass tight and that resolved about 98% of that pet peave! Put some cloth between the metal and pliers so not to scratch it.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 06-01-2016, 06:11 PM   #3
I'm not sure if it is the same issue, but DW was complaining about her window squeaking. I put some slide seal conditioner on the rubber seals and no complaints last weekend! 135 miles across the mostly gravel Denali Highway put it to a serious test. In our case in don't think it was the frame as much as the glass/rubber.
akcampr is offline   Reply With Quote
frame
