Old 12-01-2015, 10:59 AM   #1
chrisbailey13's Avatar
Side Marker Out
I have an interesting problem that I have not been able to find a solution for using the search.
My Left Front Side marker is not coming on, subsequently, when I turn the headlights on the cameras turn on the left side camera and I can't change it as long as the lights are on. If I use the right turn signal, the rear view camera comes on.
I tried changing the bulb (194) and it didn't work, I tried using a bulb from the other side of the coach, just incase there was something special about the bulb I was replacing, no luck, I tested the socket with a meter and there is voltage to the light socket (11.5-12.5 volts) when the lights are on.
HELP!
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 12-01-2015, 12:31 PM   #2
RVnut's Avatar
Sometimes when the lights act weird like that it may be a bad ground in that light socket.. At least that was usually the problem when I was a mechanic
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 12-01-2015, 01:38 PM   #3
DarrenK's Avatar
+1
Ground is more difficult to test, but I'd bet big money that's the culprit. Look for a corroded, loose, or painted ring terminal attached to the frame somewhere near the marker fixture. For verification, you can run a wire from a known good grounding point...
DarrenK is offline   Reply With Quote
Old 12-04-2015, 02:54 PM   #4
So,
After troubleshooting and finding the ground that controls the front lights (Side markers, and front park lights), Cleaning the contact and making sure there was a good ground to the chassis, I still couldn't get the left front side maker to work. So I decided to see if it would work while the turn signal was engaged.
That's when I saw it!!!!!
the left front turn signal wasn't blinking. Could it be that simple????
I removed the bulb from the housing and as soon as I pulled it out it started blinking (it was loose in the socket). when it started blinking so did the Side marker
When I turned the blinkers off, the side marker lit up as it should, and the cameras worked accordingly.
Simple solution for a confusing problem.
Old 12-09-2015, 01:19 PM   #5
That just proves the point that an electricians best friend is a hammer, tap tap tap!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 12-09-2015, 08:19 PM   #6
Make sure you have the lens on correctly. It will fit both ways but only the right way will snap in place.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 12-10-2015, 11:46 AM   #7
Good heads up mogman!
sherman12
