Old 10-17-2014, 11:26 PM   #1
Side view cameras??
Anyone know if I can purchase and install the side view camera option to my 2010 Georgetown.. At the moment all it has is the rear view camera.. Any help or info would be appreciated..
Thanks in advance.l
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-17-2014, 11:45 PM   #2
Iggy's Avatar
Does the present rear camera screen have any additional video inputs on the back?
That would be the first thing I would check.
Old 10-17-2014, 11:48 PM   #3
Haven't looked behind it.. Can't see how to take it out since it appears to be recessed flat against the dash..I'm guessing I will have to remove the entire fascia plate to get behind the monitor..
Old 10-19-2014, 10:32 AM   #4
ramair's Avatar
I have had on occasion the right camera not working and there is a quick connect which is located in the front engine compartment just follow the wire from camera up and you will see the connection. Up plug there and reinstall and this has solved my issue. If you have no right/Left you may have to cycle the power off then back on. Fount this out by the dealer. Hope this helps. Let us know...
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 10-19-2014, 10:54 AM   #5
Iggy's Avatar
Love to see a picture of what you are talking about.
Didn't know a plug existed in the engine compartment only knew about the grounding on the drivers vertical post.
Old 10-19-2014, 09:43 PM   #6
ramair's Avatar
I will try to get some pictures tomorrow and get them posted.
2015 Ford Taurus
Our Baby Dachshund
Cammie
Old 10-20-2014, 11:38 AM   #7
ramair's Avatar
here are 3 pictures of where the connections are for your side cameras.
Pic #1 is the left turn signal.
Pic # 2 and #3 is the right and is by your coolant tank.
Hope this helps.
Name:	2014-10-20 11.21.38.jpg
ID:	65078   Click image for larger version
Name:	2014-10-20 11.21.20.jpg
ID:	65079   Click image for larger version
Name:	2014-10-20 11.21.08.jpg
2015 Ford Taurus
Our Baby Dachshund
Cammie
