Old 04-24-2014, 11:36 PM   #1
Simulated wheels
I've got a Georgetown 328 2014 with the simulated aluminum wheels (hubcaps). I have a special tool to remove the nuts that hold them on, but they are so tight that I can't budge them. The tool flexes if I apply too much pressure. I'm just about ready to take a normal socket and my breaker bar to it. Question....is there a secret to getting these loose, or did somebody just over torque them?
Scagsdale is offline   Reply With Quote
Old 04-25-2014, 12:12 AM   #2
Iggy's Avatar
The tool is designed to remove the fake 3 or 4 caps not all of them.
If you look closely the fake caps have a notch in them.
If you remove these and the nuts the rest of the plate will come off and reveal the true lug nuts.
Hope this helps. Here is a picture of my 22.5" rims
Old 04-25-2014, 04:43 AM   #3
cjd10's Avatar
Mine were on so tight from the factory I had to use a regular wrench and socket to get them off the first time. They will make noise if they are not put back on tight enough.
I usually just tap each one to find the real ones you have to take off.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 04-25-2014, 06:23 AM   #4
Same here, overtorqued at the factory. As mentioned, use a regular socket and bar to get them loose and then install them with the provided T handle. On our 19.5 wheels there are 3 of them and they are the only ones with notches on the sides.
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-25-2014, 09:16 AM   #5
Thanks, all! Breaker bar it is.
Old 04-25-2014, 05:05 PM   #6
abjb's Avatar
Ours were MOST DEFINITELY NOT over torqued at the factory.
Lost one off the R front (how would you like to take one of those in the windshield).
All 3 were loose on the right rear, hub cap making so much noise we could hear it.
I thought a bearing was going out with less than 1K miles.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-25-2014, 07:28 PM   #7
Carl & Karen
Carl22's Avatar
Does anyone know where I can purchase the T-handle style wrench. I have bought the plier style one from Camping World but it just bends and flexs (cheap design). I have looked all over (Flying J's & other truck stops) no luck. Looking for suggestions.
2006 Georgetown SE 350
Carl & Karen
2006 Georgetown 350 SE DS
2001 Saturn Toad
Carl22 is offline   Reply With Quote
Old 04-25-2014, 08:34 PM   #8
Carmel's Avatar
As I don't have a special wrench to remove these nuts, do the ones with the indents unscrew ?
Carmel is offline   Reply With Quote
Old 04-25-2014, 09:31 PM   #9
Berkshire 390QS
NO3putt's Avatar
Dicor Corp has the installation tool for the simulators for $8.50. Not sure if you have the fastline simulators or the versa liner simulators? I would just call them and they will work with you to make sure you get the correct tool. That's what we did when one of the 4" center caps came up missing and they told me what to order. their number is 800-837-2059
NO3putt is online now   Reply With Quote
Old 04-25-2014, 09:47 PM   #10
You just need a socket wrench with an extension - the provided tool is worthless
ttincali is offline   Reply With Quote
wheel
