Old 03-02-2014, 04:40 PM   #1
sirius radio
Our sirius keeps cutting in and out, anyone else do that? 2013 350 ts. Where is the ant?
thegoodlife is offline   Reply With Quote
Old 03-02-2014, 04:57 PM   #2
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Sirus Radio
Post more info for your rig and maybe someone with the same rig will respond. I am not familiar with a 350 TS. I have a Windjammer 3001W and the antenna is on the roof directly over the entertainment center. It is on a metal plate. The antenna is about an inch high and about 1 1/2 inches square. I would look on the roof over where the unit is installed. Frank
Eaglelover is offline   Reply With Quote
Old 03-02-2014, 04:59 PM   #3
TURBS's Avatar
Antenna should be on the roof.
Are there tree's in the way?
I think "and I could be wrong" sirius needs clear view of southern sky.
TURBS
Think spring!
The last man standing also has a sharpie
Old 03-02-2014, 05:00 PM   #4
My rig is a 2013 Georgetown XL 350TS any help would be appreciated.
Old 03-02-2014, 05:25 PM   #5
Eaglelover's Avatar
Sirius Radio
Another thought. The satellite is set to give coverage over the entire US. The East and West coasts have some spots where the signal is weaker because of hills and treas. In my truck when I am driving on the East coast i can loose service because of valleys and trees. Frank
Just brought up your floor plan and I see it is a motor home. The antenna could also be on the roof over driving position. If you are loosing signal while driving, it may be normal depending on the terrain.
Old 03-02-2014, 05:36 PM   #6
I have a 2014 xl 378 they put the antenna in dash behind the gauges on a metal plate why they put it there is beyond me should have been installed on roof mine will cut off when your not pointed the right direction
kgreen is offline   Reply With Quote
Old 03-02-2014, 05:39 PM   #7
Thanks all for the info. I will be contacting FR to complain in the morning.
Old 03-06-2014, 01:07 PM   #8
ramair's Avatar
I had my ant mounted on the roof above passengers head. they used sealant to adhere the ant. to the roof. I have no issues with reception no matter where I travel.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-06-2014, 03:35 PM   #9
Where are you located? We currently have temporary outages in Portland, OR, Memphis, TN, Kansas City, MO, Bronx, NY, and Fullerton, CA.
If you continue to have signal issues, feel free to reach out to us at:
https://listenercare.siriusxm.com/app/digital_ask/incidents.c$social_media/638
Thanks,
Jess
SiriusXM Digital Care Team
SXM_Help is offline   Reply With Quote
