Old 08-27-2016, 10:00 AM   #1
Slack in cables on slides
We are out on our first trip in the motor home. Everything is going well love our Georgetown 328ts. But I was sitting outside watching tv and noticed that the top cables on the bedroom slide has slack in them unlike the others. Is there a way to tighten these back up.
Name:	ImageUploadedByForest River Forums1472309962.817091.jpg
ID:	118543Click image for larger version
Name:	ImageUploadedByForest River Forums1472309997.470364.jpg
Marine007 is offline   Reply With Quote
Old 08-27-2016, 10:12 AM   #2
I don't think your slide is all the way out.
JohnVtx is offline   Reply With Quote
Old 08-27-2016, 10:16 AM   #3
The slide will not go out any further I think my cable just need to be adjusted
Old 08-27-2016, 10:22 AM   #4
Your windows should be fully exposed. You slide at least at the top needs to come out more. On the inside of rv is slide up against wall at the top or do you have a gap?
Old 08-27-2016, 10:30 AM   #5
Check for an obstruction on your slide roof, like a smoke alarm falling on to it
Old 08-27-2016, 11:11 AM   #6
There are no obstruction and the slide is fully out with no gaps
Old 08-27-2016, 11:24 AM   #7
Attachment 118543Attachment 118544
Yes, you can tighten them.
You'll want to learn more about the accu-slide system before making any radical changes, however if you pull down the facia board inside the camper on the top of the slide you will find all eight cables for the slide.
You will be able to find the too loose ones fairly easy. Don't over tighten them; just take the slack out.
325BH is offline   Reply With Quote
Old 08-27-2016, 11:30 AM   #8
Thank you 325 bh. My father in law said the same thing I will do my research and then make adjustments
Old 08-27-2016, 12:13 PM   #9
Jesse's Avatar
Pic inside
Please show us a picture of the inside of that slide out. From six feet away.
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 08-27-2016, 12:33 PM   #10
Your cables should be taunt at all times, in , out, or in between never any slack, lousy set up, I have one cable slide on our Charleston , but I would agree slide appears Not to be fully extended . Even still cables should be taunt .
Can't believe FR is still using them.
Good luck
SEAYALL is offline   Reply With Quote
Old 08-27-2016, 12:46 PM   #11
Name:	ImageUploadedByForest River Forums1472319893.237354.jpg
The slide is all the way out
Old 08-27-2016, 01:01 PM   #12
Attachment 118558
Umm. looking at side window, I had a Georgetown 2012 , seemed Window was evenly spaced. So a cable or pulley thing. FYI. Amazon sells cable kit, I bought two to carry with me, reasonably priced $20. Something
Old 08-27-2016, 01:40 PM   #13
Evereddie's Avatar
That slide looks to have a tilt in it, or at least in the photo. And yes, the full window should be exposed more but the inside does look correct. Hmmm?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 08-27-2016, 01:49 PM   #14
Slide should go out far enough to expose the entire window(s). Something is amiss and is keeping it from fully extending. I would be removing the facia boards and having a look or bring the slide in about a foot and look all around the slide for something stopping it.
Old 08-27-2016, 02:15 PM   #15
Measure top and bottom distance from wall to outside it's not the same.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 08-27-2016, 02:22 PM   #16
slide definetly not all the way out
check other units at dealer with slide all the way out to compare.
rich1234 is offline   Reply With Quote
Old 08-27-2016, 03:40 PM   #17
I have the same unit and mine only goes out that far.
Sundance54 is offline   Reply With Quote
Old 08-27-2016, 03:51 PM   #18
So I probably just need to take the slack out of it. I'll take it to the shop when we get back from our trip to make sure everything is in line and where it's supposed to be
Old 08-27-2016, 05:33 PM   #19
Marine007, I see the same thing that others see. The gap between RV and top of slide is considerably shorter than the gap between RV and bottom of slide. In normal operation you would see the gap to be pretty even
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 08-27-2016, 05:35 PM   #20
I thought the same thing but it's 18 1/2 in. on top and bottom
cable, slide, slide out
