Old 05-26-2014, 10:01 AM   #11
Originally Posted by Krazymace View Post
The shock on mine is either the wrong one or installed incorrectly. When opening the door, it pulls against the door frame. If you leave the door open, it won't stay in place if there is even a whisper of wind. No way to latch it. Result was that my door was pulled apart and the dealer is replacing under warranty!
Can you post a pic. I'd like to see what you are talking about. Ours shock is okay even though the installer snapped a sheet metal screw.
One thing I've noticed is that the door/frame seems to be temperature sensitive. We are parked in a spot where the sun hits the door side all morning and you really have to slam it. Then in the evenings it seems to be easier to close. Something is expanding causing a bind.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-26-2014, 10:03 AM   #12
Krazymace's Avatar
Can't post a pic Al. Dealer has had it for 3 weeks. Waiting on a new door from FR.
Krazymace is offline   Reply With Quote
Old 05-26-2014, 10:07 AM   #13
Oh wow. You weren't kidding when you said your door was pulled apart. We took ours in to replace the awning two weeks ago and they hadn't even ordered the awning so we picked it up for the weekend. When we drop it off again, I'm going to have them fix the door. DW is not happy with having to slam the door when the sun is on that side.
Old 05-26-2014, 10:27 AM   #14
That's true OldCoot. There isn't much room in ours due to the awning and probably why they installed them the way they are. I wish the shock had a dead spot like you say where it will stop pushing when the door is an X amount of inches from closing. I need to play with it some to see what works best.
Had the same awning arm restriction on my 5er. It now clears the arm by about 1-1/2" when fully open which is about 115°.
Old 05-26-2014, 10:42 AM   #15
Krazymace's Avatar
Pulled the inside frame away from the body of the door. Really isn't anything to anchor back to except styrofoam. Pretty lame door construction. I'm definitely going to have to deal with the shock or it will happen again.
Old 05-26-2014, 01:18 PM   #16
Originally Posted by MtnGuy View Post
Our door gets difficult to close occasionally, and a shot of WD-40 on the strike plate and latch is needed to get the door closing good again.
A shot of dry sillycone on the latch works for us. Still needed to "train" the DW that you don't need to slam the door. Slow your closing and it moves like butter.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-26-2014, 03:13 PM   #17
I'm going to try that out when I get the awning replaced. Thanks.
Old 05-26-2014, 04:14 PM   #18
Timex's Avatar
I'm not condemning those who have shocks on their doors, to each his own. Crazy as it sounds, that was one of the deciding factors in which TT we chose. We didn't like having to deal with the shock and having to keep it adjusted. I do have the self closing spring attached. It helps the big door swing toward the door jam. A little push and it is shut. Now, the screen door is a different story. It will slam when it closes. I've put some pads to try to cushion the slam but it keeps the big door from shutting cleanly. When closing the big door I try to use the latch do ease it closed. I too don't like slamming the door. I just don't think you should have to slam the door to close it. Back in the day, you had to close car doors by slamming. Today's cars, they close very softly.
As always, Just My Opinion.
Timex is offline   Reply With Quote
Old 05-26-2014, 04:32 PM   #19
You are just kidding when your determining factor was a shock vs. spring, right? You can install either one with a few screws. Not sure what you mean by having to keep adjusting the shock. Once set, it's done...no adjustments. Back in the day you did have to slam doors on cars except for Mercedes Benz, if you could afford one. I personally wouldn't compare a car's door to an RV's door.
Could you please post a picture of your spring? It may be something we could do.
Old 05-26-2014, 05:12 PM   #20
Timex's Avatar
I guess what I meant about not choosing the TT because of the shock, I could see problems with it being screwed/riveted to the door and door frame area. 1 more thing to keep up with. I use this excuse when I lose a ball playing golf, "I didn't like that ball anyway". I used that excuse to sway the BOSS away from that TT when we were TT shopping. Here's the spring I have RV Screen Door Closer - Camco 44133 - Screen Doors - Camping World. If you mount the screws per the instructions(like I did) it closes the screen door a little too strong for my liking but it helps the big door. If the screen door is what you want closed completely, this what you want. If the big door is what you want closed completely, this won't do it. It does get it to where just a little push or using the latch to close it completely will do. If you are going in/out a lot and don't need it to close, this works great.
To each his own about the shock, just wasn't for me.
door
