Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Motorhomes > General Motorhome Discussion > Georgetown
Old 11-11-2011, 04:46 AM   #1
Question Slide comes out 5 or 6 inches on its own
HI I have a 2011 geogetown 378 and notice that my right side slide will creep out about 5 inches when left in the closed position for a week or so & cabin power is disconnected.
No problem with other two slides.
Any ideas what is causing this?
Homejames is offline   Reply With Quote
Old 11-11-2011, 06:15 AM   #2
Fire Instructor's Avatar
Is it sitting level?
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-11-2011, 06:30 AM   #3
Boyd's Avatar
Is the slide moved in and out by hydraulic or motor?
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 11-11-2011, 07:11 AM   #4
Cherck the fluid level in the pump tank....also activating the jacks sometimes will make the slides move a bit on mine but never 5 inches..
polkatronron is offline   Reply With Quote
Old 11-11-2011, 07:41 AM   #5
Thanks for the ideas
It is level, works on hydraulic. I'll check the fluid level.
Any idea where it is on a 378?
Old 11-11-2011, 08:44 AM   #6
Its under the inside steps. Remove the steps using the barrel key to unlock. Look to the rear of the coach from the batteries.
ohiobill is offline   Reply With Quote
Old 11-17-2011, 10:30 AM   #7
jsutherl's Avatar
My rear slide comes out about an inch when I start the engine. At the same time the main slide apears to get loose when I do that. So that the next time I sit down on the dinette after starting the engine the bottom of the slide pops out a half inch or so.
I assume that starting the engine resets the valves on the hydraulic pump or something but I haven't investigated further yet.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 01-05-2012, 09:32 AM   #8
Hi
Finally got to root of my slide problem. Dealer found a leak in hydraulic lines as well as in at pump. Waiting now for replacement pump.
During the troubleshooting I did I found that the pump also controls the leveling jacks. And when you check you fluid levels jacks up and slides in.
Old 01-05-2012, 09:29 PM   #9
fbconsults
Don't forget to keep a lookout for blisters on the orange hydraulic lines, they are prone to that. Just had 9 replaced on my 2011 378, Lippert claims the new ones are better quality than oem.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2003 Chevy Tracker 4x4
fbconsults is offline   Reply With Quote
Old 01-06-2012, 08:13 AM   #10
Amen...just got our rig back from having the blistered orange lines replaced by Forest River.....
Lostdog
(Chuck n Terri)
2011 Georgetown 378TS in FireMist
2010 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Close [X]
